HY!
Gibt es einen Nachfolger der Dual Band Wireless-AC 7620 Karte?
Mein Wlan macht 1,7Gbit/s und diekarte leider nur 887 Mbit/s.
Möchte gerne schneller werden.
Hello SFalko,
Thanks for using our support communities, please be aware that we are posting our response in English since this is the language supported for these forums. We understand you would like to know the successor for the Intel® Dual Band Wireless-AC 7260, we will be glad to answer your question.
The AC 7260 has reached End of Life, and Intel is actually manufacturing newer wireless adapters. In fact, the Intel® Wireless-AC 9260 can reach 1.73Gbps maximum speeds, by using 802.11ac, 2x2 and channels of 160 MHz. Please check this link for a https://ark.intel.com/compare/75439,99445 Spec Comparison of the 2 adapters.
If you are planning to replace your existing adapter with a newer one, we strongly advise you to check with the https://www.intel.com/content/www/us/en/support/topics/OEMs.html Computer Manufacturer Support, they will be able to confirm if your PC is compatible with a newer wireless card. Keep in mind that the AC 7260 was available in HMC and M.2 form factors, and the 9260 is only available in M.2, so your PC may not support a newer adapter. Even if the new adapter fits in your PC, a custom integration may not work due to Manufacturer Limitations, PCIe* version compatibility, Regulatory Issues, or Driver Limitations. Please review the following documents for information:
https://www.intel.com/content/www/us/en/support/articles/000005846/network-and-i-o/wireless-networking.html Why Doesn't My Laptop Recognize My New Intel® Wireless Adapter?
https://www.intel.com/content/www/us/en/support/articles/000005687/network-and-i-o/wireless-networking.html Regulatory Information Regarding Wireless Hardware Installation or Upgrade
We hope this information helps.
Jonathan B.
Hallo!
Dies ist mir klar, das es sein kann , das die Karte nicht läuft. Aber sind die Anschlüsse von Intel® Wireless-AC 9260 gleich mit der Intel® Dual Band Wireless-AC 7260. Ich habe einen Händler angeschrieben, der sagte sie würde nicht passen.
Deshalb habe ich bei Ihnen nach gefragt.
Hello SFalko,
If the adapters use the same form factor (M.2), then it may work. However, we recommend you to confirm with the Computer Manufacturer if they support this configuration before proceeding with the replacement, keep in mind that there are others factors as was mentioned in the documents we provided before.
We hope this helps resolve your inquiry.
Jonathan B.
