Community
cancel
Showing results for
Search instead for
Did you mean:
mhans13
Need Wlan driver for Windows 8.1 Samsung Ultrabook
So i just formatted my HDD.
And installed windows 8.1
Fresh install.
The laptop is:
Samsung ATIV Book 9 NP900X3F
http://www.samsung.com/us/computer/pcs/NP900X3F-K01US ATIV Book 9 (NP900X3F) | Samsung Laptops
I tried to download from intels homepage the official wi fi driver and from samsungs homepage.
and i did not succed i cant connect any wifi on the laptop.
I hope someone can help me already tried:
Intel® Centrino® Advanced-N 6235 drivers and they are not working :-(
I really would like the Wifi on my computer working
Normally windows 8.1 and windows 8 have the wifi set by default no needs for driver . but this time i need it. hope you can help me.
Jose_H_Intel1
I am sorry for your issue.
At first I would like to suggest this two steps verification:
  1. You may want to check that your system has WiFi connectivity enabled. The system manufacturers usually provide a hardware or software switch for this purpose, sometimes is a combination of both. You may want to take a look into the manufacturer's website just in case you are missing a wireless software switch needed to activate this feature. http://www.intel.com/support/wireless/wlan/sb/cs-020275.htm Intel� Wi-Fi Products; Wireless radio cannot be enabled from software
  2. Once you checked the first step you may want to check the status of the Intel® wireless adapter driver in Device Manager (Control Panel). By having the WiFi switch enabled the wireless adapter should appear there and show: "This device is working properly". http://www.intel.com/support/wireless/wlan/sb/CS-025417.htm Intel� Wi-Fi Products; Identify your Intel wireless adapter and driver version number
It is also possible that the device appears as "unknown device" or simply "network adapter" because the driver is missing. It could really help connecting via wired Ethernet in order to install the Intel® driver with the http://www.intel.com/p/en_US/support/detect?iid=dc_iduu Intel® Driver Update Utility or even let Windows* install its inbox driver via Windows* Updates.
Based on your description I believe this is more of a software issue because of the fresh operating system install, right? Therefore you may consider using the Windows* version provided by the system manufacturer (OEM) instead of a retail version. However, you may need to contact the system manufacturer for assistance in case the wireless adapter does not appear at all after the recommendations presented above.
