Wireless
7443 Discussions
Not able to connect iPhone and iPad to the Intel my WIFI PAN at the same time
I have created a Intel my WIFI PAN.
I can connect my iPhone or my iPad seperately to the PAN and use the shared internet connection of my notebook.
But when I try to connect both at the same time, one of the two devices is not able to get the connection.
Every time the device which opens the first connection is succesful and the second is disconnected after a few seconds of trying.
In the window of the administration tool the device is shown as connected one second and then the connection is shown as failed on the device
iPad and iPhone could be exchanged.. If at first the iPad is connected then the iPhone is not able to connect.
If at first the iPhone is connected, then the iPad is not able to connect.
Seperately both devices work, but together only the first one.
Maybe anybody has a idea or a Intel System Engineer could advice how to trace the attempt of connecting to the PAN and then analyse the problem.
my system data:
Lenovo Thinkpad x201 with
Intel Centrino Ultimate-N 6300 AGN
Windows 7 Prof. 64-Bit
Intel My WIFI Utility 14.0.1.0
Thank you for your post. Sorry to hear that you were/are experiencing trouble with the Intel® My WiFi tool.
The tool is capable of connecting up to 8 simultaneous devices, but it is completely dependent on the integration, most laptops will only be capable of handling 2-3 active connections. That includes the connection to the router, also if there is a lot if interference it would also cause a devices disconnects, you may check in the advanced tab in the adapter properties, to make sure that the transmit power is set to highest.
At this point, the latest version 15.2 no longer carries the Intel® My WiFi technology as a tool, it has been replaced with the in my WiFi Dashboard. If you do wish to use the Intel® My WiFi technology tool you would need to install driver version 14.3. See the links below for the above mentioned downloads,
Software and Drivers for Windows 7 64-Bit version: 14.3
http://downloadcenter.intel.com/confirm.aspx?httpDown=http://downloadmirror.intel.com/21045/eng/Wireless_14.3.1_s64.exe&lang=eng&Dwnldid=21045&DownloadType=%0ASoftware+Applications%0A&OSFullname=Windows+7+%2864-bit%29*&ProductID=3316
Software and Drivers for Windows 7 64-Bit version: 15.2
http://downloadcenter.intel.com/confirm.aspx?httpDown=http://downloadmirror.intel.com/21560/eng/Wireless_15.2.0_s64.exe&lang=eng&Dwnldid=21560&DownloadType=Software+Applicationseng&ProductID=3316&ProductFamily=Wireless+Networking&ProductLine=Intel%C2%AE+Centrino%C2%AE+Wi-Fi+Products&ProductProduct=Intel%C2%AE+Centrino%C2%AE+Advanced-N+6205 http://downloadcenter.intel.com/confirm.aspx?httpDown=http://downloadmirror.intel.com/21560/eng/Wireless_15.2.0_s64.exe&lang=eng&Dwnldid=21560&DownloadType=Software+Applicationseng&ProductID=3316&ProductFamily=Wireless+Networking&ProductLine=Intel%C2%AE+Centrino%C2%AE+Wi-Fi+Products&ProductProduct=Intel%C2%AE+Centrino%C2%AE+Advanced-N+6205
Intel® My WiFi Dashboard Software for Windows 7 64-Bit (for version:15.2)
http://downloadcenter.intel.com/confirm.aspx?httpDown=http://downloadmirror.intel.com/21562/eng/Intel_My_WiFi_Dashboard_15.2.0_s64.msi&lang=eng&Dwnldid=21562&DownloadType=Software+Applicationseng&ProductID=3316&ProductFamily=Wireless+Networking&ProductLine=Intel%C2%AE+Centrino%C2%AE+Wi-Fi+Products&ProductProduct=Intel%C2%AE+Centrino%C2%AE+Advanced-... http://downloadcenter.intel.com/confirm.aspx?httpDown=http://downloadmirror.intel.com/21562/eng/Intel_My_WiFi_Dashboard_15.2.0_s64.msi&lang=eng&Dwnldid=21562&DownloadType=Software+Applicationseng&ProductID=3316&ProductFamily=Wireless+Networking&ProductLine=Intel%C2%AE+Centrino%C2%AE+Wi-Fi+Products&ProductProduct=Intel%C2%AE+Centrino%C2%AE+Advanced-...
