Wireless
8781 Discussions
Oscillating 5G connection
Ccastiell
Hello everything is fine? I have a problem with my 5G connection, I use a Samsung notebook with the Wireless-AC 9462 network adapter. Before I formatted the computer, my internet connection was perfect, after I formatted it it started to oscillate, and it's not my router , nor my internet provider. I've already reinstalled Windows, the drivers and even disabled and enabled the adapter and it didn't help. Can anyone help me?
Earl_Intel
Hi Ccastiell,
To better assist you and determine the most appropriate resolution, could you please provide the needed details listed below:
  • What is the symptom of the issue?
  • What is the exact Windows OS version are you using before you formatted the system?
  • What is the exact Windows OS version did you install that cause this issue?
  • Have tried a roll back to a previous driver version for testing?
  • What steps do you take to reproduce your issue?
Kindly run this on your system so that I can also gauge the following peripherals and the driver versions that you have:
Intel® System Support Utility for Windows*
Once finished downloading, open the tool, click on scan (leave the default items checked), click next, then save the system information to a .txt file. Please provide us the .txt file.
Earl E.
Earl_Intel
Hi Ccastiell,
Earl E.
Earl_Intel
Hi Ccastiell,
Earl E.
