Wireless
8326 Discussions
PC install intel 18260, But it show the wifi card is intel 8260.
LChen85
Hi Guys,
I have issue.
I use intel 18260(connect with Intel Antenna-M 10041R) wifi card install to Asus PCE-AC55BT B1 and install my PC (Windows 10).
PC has install intel18260 driver ver. 20.40.0
But Windows Wifi interface show.. it is "intel 8260" ?
I have not idea.
Hello evangelive,
We understand you swapped the adapter on your ASUS* PCIe WiFi adapter for an Intel Tri-Band Wireless-AC 18260. Since this is not a supported usage, we can't guarantee it will function properly.
However, I believe what you are seeing is an expected scenario as described in our article: https://www.intel.com/content/www/us/en/support/articles/000024989/network-and-i-o/wireless-networking.html Different Adapter Name in Device Manager for Certain Intel® Wireless Gigabit Adapters.
What happens is that your wireless is made up of three separate modules: Wi-FI, WiGig, and Bluetooth®. Each is displayed separately in device manager:
We hope this helps.
Carlos A.
LChen85
Hi Carlos,
Thanks for your reply.
i have a issue.
if i have a intel 18260 wifi card(On PC or Laptop) and a 11ad AP(Netgear R9000).
can i use the wifi 11ad to connect with AP?
Do i not need other device? or dock ?
Hello evangelive,
Intel® WiGig doesn't support direct wireless access to the Internet (using 802.11ad). However, you can connect wirelessly to a dock which in turn can support a wired Ethernet connection.
- https://www.intel.com/content/www/us/en/support/articles/000007805/network-and-i-o/wireless-networking.html Frequently Asked Questions for Intel® WiGig
For more information, you can also see our https://www.intel.com/content/www/us/en/support/articles/000007700/network-and-i-o/wireless-networking.html Frequently Asked Questions for Intel® Wireless Docking.
Otherwise, you may look into the https://www.intel.com/content/dam/www/public/us/en/documents/product-briefs/dual-band-wireless-ac-9260-brief.pdf Intel® Wireless-AC 9260, which supports up to 1.73 Gbps and downlink MU-MIMO for faster 802.11ac connectivity.
Carlos A.
