Wireless
8403 Discussions
Pktgen DPDK Troubleshooting
ABoub
I need help to run pktgen-dpdk on our platform (Xeon PCies/Red rock canyon switch) to check the frame rate/Bandwith.
Currently, the trace of the pktgen binary execution on an the target is:
pktgen -l 0-4 -n 3 --proc-type auto --socket-mem 512 -- -T -P -p 0x30 -m "[1:3].0, [2:4].1"
Copyright (c) <2010-2017>, Intel Corporation. All rights reserved. Powered by DPDK
EAL: Detected 8 lcore(s)
EAL: Auto-detected process type: PRIMARY
EAL: 1024 hugepages of size 2097152 reserved, but no mounted hugetlbfs found for that size
EAL: Probing VFIO support...
EAL: cannot open /proc/self/numa_maps, consider that all memory is in socket_id 0
EAL: PCI device 0000:01:00.0 on NUMA socket 0
EAL: probe driver: 8086:15a4 net_fm10k
EAL: PCI device 0000:02:00.0 on NUMA socket 0
EAL: PCI device 0000:04:00.0 on NUMA socket 0
EAL: probe driver: 8086:15ab net_ixgbe
EAL: PCI device 0000:04:00.1 on NUMA socket 0
EAL: PCI device 0000:04:10.1 on NUMA socket 0
EAL: probe driver: 8086:15a8 net_ixgbe_vf
EAL: PCI device 0000:04:10.3 on NUMA socket 0
EAL: PCI device 0000:04:10.5 on NUMA socket 0
EAL: PCI device 0000:06:00.0 on NUMA socket 0
EAL: PCI device 0000:08:00.0 on NUMA socket 0
EAL: probe driver: 8086:1533 net_e1000_igb
Lua 5.3.1 Copyright (C) 1994-2015 Lua.org, PUC-Rio
Pktgen created by: Keith Wiles -- >>> Powered by DPDK <<<</strong>
Packet Burst 64, RX Desc 1024, TX Desc 2048, mbufs/port 16384, mbuf cache 2048
=== port to lcore mapping table (# lcores 5) ===
lcore: 0 1 2 3 4 Total
port 0: ( D: T) ( 1: 0) ( 0: 0) ( 0: 1) ( 0: 0) = ( 1: 1)
port 1: ( D: T) ( 0: 0) ( 1: 0) ( 0: 0) ( 0: 1) = ( 1: 1)
Total : ( 0: 0) ( 1: 0) ( 1: 0) ( 0: 1) ( 0: 1)
Display and Timer on lcore 0, rx:tx counts per port/lcore
Configuring 2 ports, MBUF Size 2240, MBUF Cache Size 2048
Lcore:
1, RX-Only
RX_cnt( 1): (pid= 0:qid= 0)
2, RX-Only
RX_cnt( 1): (pid= 1:qid= 0)
3, TX-Only
TX_cnt( 1): (pid= 0:qid= 0)
4, TX-Only
TX_cnt( 1): (pid= 1:qid= 0)
Port :
0, nb_lcores 2, private 0x9f4e40, lcores: 1 3
1, nb_lcores 2, private 0x9f79a8, lcores: 2 4
** Default Info (0000:01:00.0, if_index:0) **
max_vfs : 0, min_rx_bufsize : 256, max_rx_pktlen : 15360
max_rx_queues : 128, ma...
Hi Anasboubakri,
Thank you for posting in Wired Communities. The Intel® DPDK questions and technical problems should be reported through the Intel® Premier Support site
http://premier.intel.com/premier http://premier.intel.com/premier or access your IBL account and click
the Intel® Premier Support link to enter issues under the Product Name
"Data Plane Development Kit (DPDK)", you will be routed to the support team to better assist you. Thank you.
Sharon T
