Dear Intel manager,
Hello, Good day to you.
I am looking for KC certificate of 8265NGW model.
Can I get KC certificate for 8265NGW?
8265NGW's KC certification number is MSIP-CRM-INT-8265NGW.
I look forward to your reply.
Thank you & best regards.
Hello KIMDS,
I will work on your request. As soon as I have an update, I will let you know.
Steven G.
Hi @KIMDS,
Thank you for your time. In this case, Korea is antenna dependent country, so the use of the certificate must be done in conjunction with the right antenna. And it is recommended to contact third party laboratory which is Dekra to get this certificate.
If you need any additional information, please submit a new question, as this thread will no longer be monitored.
Carlos L.
