Wireless
7441 Discussions
Return codes "errorlevel" from the Wireless_18.21.0_Win64 installation?
Hi
Where could I find a list over the return codes for the "Wireless_18.2x.xx.zip " drivers?
I need them, but can't find them
Kurt
ASouz7
b115242,
Is there an specific reason you need this piece of information?
I would like to find out the result after I run this setup on several hundred PCs.
I found out that the this installation return different results for different PCs.
0 for some models
3010 for one.
I assume that the return codes are the same a MS SCCM expect. If so, I am satisfied.
Is there any reason why this is a secret, and not included with relevant information for the drivers?
