Hello Jose,
Microsoft have agreed to replace my laptop. Thanks once again for Intels support.
thanks
Hello All,
UPDATE.
I have now attached a copy of the log results of running the Intel System Support Utility on my Laptop.
Hello @roker
We sincerely regret that this is happening to you using your Intel® Wi-Fi 6 AX200 (Gig+), please allow us to help you with that.
Please answer the following:
· Is this issue happening at home, office environment or both?
· Have you checked if this issue happens on different networks?
· Have you modified any Wi-Fi adapter settings before issue appears?
Jose B.
Hello Jose,
Thanks for reviewing and helping me. I have answered your questions inline below.
[roker] Home only.
[roker] Not yet. BUT, I have two Smartphones and another Microsoft GO laptop not experiencing slow thoughput to the Internet off the same Home wireless network. And I did perform a comparative speedtest.net test, at the same time, on my Smartphone next to the MSLS which I detailed in my original message.
[roker] No.
Jose....I have now also reviewed the Intel SSU dump txt file (called roker Intel SSU report 20231207a) which I had attached to this discussion. At line 708 it reported the following fatal error, actually there are many indication of this same fatal error after line 708:
"...Miniport Microsoft Wi-Fi Direct Virtual Adapter #2, {6c680111-e723-4ba8-8679-594aef86e882}, had event Fatal error: The miniport has failed a power transition to operational power.."
But there is no timestamp when this fatal error occurred and I am concerned it may have been caused by me as I did perform a restart of the Intel WiFi Adaptor (and it didn't resove the issue) within about an hour or so of running the SSU.exe because the slow throughput issue was evident. But it may be an indicator of a problem with the WiFi Adaptor..!!!
thanks
Roker
Hello roker
Please allow us to research this issue internally, we will post back as soon as we have any update.
Jose B.
Hello roker
Thank you for patiently waiting.
After checking the detailed information you provided, also the troubleshooting you have performed so far, we highly recommend contacting Microsoft for further assistance. This is because the issue could be related to the card itself.
Jose B.
Hello Jose,
thanks
