Wireless
8722 Discussions
Slow wbax200 wifi card
VAROV
Hello i have a gigabyte wbax200 aswell. my bluetooth and wifi works good but im not getting any wifi speed change im getting around 30-80 using it, its connected to a asus prime a520-e mother board and its connected to usb_12 because i dont have f_usb
David_G_Intel
Hello VAROV
Thank you for posting on the Intel️® communities. This is a Gigabyte card, it's recommended that you use their drivers and confirm specifications with them. We can make sure that your system is up to date but we need more information:
  • OS version and Build
  • Drivers tested
  • Other devices have the same issue?
  • Did you check if this device is compatible with your motherboard?
  •  Intel® System Support Utility (Intel® SSU) results
David G
David_G_Intel
David G.
David_G_Intel
David G.
