Wireless
7589 Discussions
Specific Bluetooth Wiimote Audio Problem Affecting AX200, AX201, AX210, AX211, AX401
will6
New Contributor III
Hi I know this is a very specific problem with this cards, I dont expect a fix, just for reporting purposes.
When using a Nintendo Wiimote (Manufacturing date from 2012 and newer), there is no speaker audio.
Apps that show no audio can be dolphin emulator. Or just wiimote audio player https://github.com/trigger-segfault/WiimoteLib.Net/releases
The issue is always resolved by using other brand BT card (Asus bt500, tplink ub400, ub500)
So the problem are intel cards not being able to play audio on this wiimote devices.
Always using latest driver, but this is not driver specific. Also running Windows 11.
Jocelyn_Intel
Hello, @will6
Thank you for posting on the Intel® communities.
I understand your discomfort about this wiimote issue and how frustrating it can be. As I understand that you intend to report this issue, I have submitted your report to the appropriate team in charge for visibility.
This thread will no longer be monitored. Thank you for your feedback on this.
Jocelyn M.
Jocelyn_Intel
Hello, @will6
Jocelyn M.
will6
New Contributor III
will6
New Contributor III
Let´s go to first page to get some visibility.
will6
New Contributor III
Tried driver 23.10.0.2, issue is still there.
will6
New Contributor III
23.20.0.3 was released. Issue still there.
will6
New Contributor III
23.30.0.3 issue still there.
will6
New Contributor III
Tried 23.40.0.2
Issue still not resolved.
will6
New Contributor III
Tried 23.50.0.2
Guess it´s time to fix this.
