I have some very specific questions on the 6300 adapter:
- Does WPA2 and CCKM work together?
- I have seen where a device will work with WPA and CCKM only and WPA2/CCKM did not work. I need to find out if they work together
- The device specs show that it supports fast roaming
- On every roam does the device perform a full DHCP DORA (Discover, Offer, Acknowledge, Ack)?
- The device shows fast roaming support but there is a comment (Roaming is supported only between each respective band and mode of access points)
- Can you provide more detail on how fast roaming is supported?
- Tags:
- Adapters
