Wireless
8425 Discussions
Sporadic but recurring connection dropouts on an Intel 6235 wireless adapter
Dear all,
I have the same issues of intermittent sudden connection dropouts as reported by others with the Intel Centrino Advanced-N 6235 Wifi adapter and the Intel Proset 15.x drivers!
My system is a brandnew desktop computer with an Intel i7 3770 Quad-Core CPU, an Intel Z77 chipset, an Asrock Z77E-ITX mainboard, 16 GB of RAM, and Windows 7 64-bit.
Previously, I already encountered the issue with this adapter's predecessor, the Intel Centrino 6230 and only managed to resolve it by going back to an older driver version. If my memory is correct, the Intel Proset 14.x version range worked flawlessly, but the 15.x drivers lead to the dropouts (I always use 64-bit drivers).
These can occur randomly after 5 or after 50 minutes. The adapter suddenly disconnects and won't reconnect to the wireless network unless it is reset. The wireless router itself is fine as there are over a dozen devices from all types of brands that connect regularly to it without any problem at all.
The fact that the problem occurs on two different cards (6230 and 6235) leads me to believe that there is a driver problem.
On the 6235, going back to a 14.x driver does not seem to be an option on the table, because the device seems to be only supported by 15.x versions. I already tried going back from the recent 15.2 version to the previous 15.1.1 (after uninstalling through the device manager), but the problem still persists. Now I just went back to 15.1.0 and it's been ok so far, but i'm not very optimistic.
I have tried different changes in the driver settings but with no success. The problem persists!
I'd be thankful for a solution.
Steve
Edited 9/5/2014 by John S. (Intel Customer Support).
The "/message/169514# 169514 Sporadic but recurring connection dropouts on an Intel 6235 wireless adapter" thread will be locked. This thread will remain on the forum for you to reference, but no new posts will be possible on this thread.
The 17.1.0 version of Intel® PROSet/Wireless Software and Drivers has fixes for connectivity related issues with the Intel® Centrino® Advanced-N 6235 wireless adapter. If you are still experiencing connectivity issues after installing the very latest software and drivers and you require further troubleshooting, please contact Intel Customer Support. If you prefer to ask questions, make comments, and/or receive answers on this support forum (Wireless Networking Support Community), please start a new thread or find an existing thread that matches your specific issue with your specific hardware/software.
US
Worldwide
http://www.intel.com/p/en_US/support Intel Customer Support
Note that the Intel(R) WiFi Link 6235 adapter is meant to be professionally installed by Original Equipment Manufacturer (OEM) technicians on certified systems only.
Please note that these adapters are not meant to be sold separately, your system must be compliant with the required FCC certifications in compliance with the International Special Committee for Radio Interference standards for radiated and conducted electromagnetic interference.
In this case what we recommend and encourage you to first contact the Original Equipment Manufacturer (OEM) to determine if the product is approved for use in your computer.
For additional information, refer to:
Intel® WiFi Products - Upgrade or exchange Intel® wireless adapter hardware
http://www.intel.com/support/wireless/wlan/sb/CS-006006 http://www.intel.com/support/wireless/wlan/sb/CS-006006
Intel® WiFi Products - Why doesn't my laptop recognize my new Intel wireless adapter?
http://www.intel.com/support/wireless/wlan/sb/CS-031167.htm http://www.intel.com/support/wireless/wlan/sb/CS-031167.htm
The recommendation on this case if you are trying to use a Wifi adapter in a desktop system will be to use the following model:
Intel® Centrino® Advanced-N 6205 for Desktop
http://www.intel.com/content/www/us/en/wireless-products/centrino-advanced-n-6205-desktop-brief.html Intel® Centrino® Advanced-N 6205 for Desktop: Product Brief
@Intel:
This is a very generic answer to a very specific problem.
My system (i.e. the Asrock Z77E-ITX mainboard) IS FCC compliant and I have assembled the system myself, so there's no OEM in that sense.
But if you insist, please list the technical requirements for compatibility.
I think your answer is entirely misleading as you point to the OEM or the end-user being at fault, instead of carrying out a thorough diagnosis. The adapter is recognized by the system and works 90% as expected. This thead is about eliminating a remaining (but very annoying) hickup.
The problem vanishes when switching off the 802.11n mode from the driver settings. Now, the bandwidth is smaller but there are no dropouts anymore. I only consider this as a temporary workaround rather than a permanent solution. The router is an n-router of course and all other devices work fine in n-mode.
I hope this guides Intel in their search for a solution (but are they trying at all?).
What does this answer even MEAN? I bought a new Samsung Series 5 computer with THIS ADAPTER 6235 installed, and I haven't done anything but make sure the drivers are updated in the last 5 months, but EVERY SINGLE TIME THE COMPUTER SHUTS DOWN or restarts, I have to go reconnect the WLAN. This is RIDICULOUS. I've been shrieking about this to Samsung, but they are not the problem -- INTEL is the problem. FIX THIS ISSUE!
I don't appreciate the "correct answer" being "well you installed it wrong" IT CAME ON MY LAPTOP!
I demand an answer about this. I've tried EVERYTHING to make this stupid wireless adapter work. We've bought two new routers, thinking that was the problem, though NO other device disconnects this way, and now I see -- it's a KNOWN ISSUE! Look at all of us with Series 5 Samsung notebooks, complaining.
I tell you what, since your adapter is ruining my laptop experience, how about I send it to your CEO and demand a replacement that DOES work properly?
This problem should not have been marked answered. As noted in the 13 pages of this thread, other people, myself included, have this problem with brand new partner systems. It is a problem with the adapter and/or drivers, not the system. Fix it.
etaus
Hi all, just let me add a Samsung NP530U4C to the list of devices with malfunctioning N6235 wireless adapters.
What puzzles me the most is the unbelievable lack of interest of INTEL and/or Samsung to solve the issue. After several months and a growing list of dissatisfied users I would have expected a different behavior.
Consumers, our next purchase is our greatest weapon. Let's use it !!!!
BWIn
Intel, this is not a proper answer! I've bought a Intel NUC i5 kit where you are supposed to assemble the parts by yourself. I've been working with computers and electronics for over 40 years and I think I'm qualified to assemble this kit properly. The problem is the Centrino WLAN card 6235. I've tested this card with all available compatible drivers on the Intel site and still have problems with sporadic network drops. When I tested with a USB dongle, the Asus N53, I have no problems whatsoever.
The problems with the 6235 card dates back for at least on and a half year now without Intel being able to give us any answers how to solve this. I discovered the network problems within half-hour after powering up the Intel NUC.
Don't you test your stuff Intel? This whole affair is a disgrace for Intel and you just answer this issue with a nonsense standard reply!
This is the last time I will buy any equipment with Intel Inside. You just haven't handle this problem professionally and with proper respect to your customers.
My equipment:
computer: Intel NUC i5 d54250wykh, 8GB memory, Intel 120 GB SSD
OS: Windows 8.1 64 bit
Router: Asus N66U
All drivers and firmware are the latest as of today, March 31, 2014,
Just joined up to report the same issue. I've got the samsung np700z5ch-so1us and it packs this wireless card. Ironically i got this to replace my old laptop which had more severe wireless issues. Anyway this problem is driving me nuts, because if i'm playing a game about every 3 minutes I personally lag for about 3-10 seconds. It can't be the router because all my friends are sitting next to me playing (Starcraft 2 specifically) and they have no issues. If it were a bandwidth issue then they would feel it too. I'm currently downloading something on steam and took a screen shot to show the issue because my download rate is plagued with occasional dl rate "valleys". I don't see any way to upload that. Also my drivers are up to date, I've tried disabling n-mode and ensuring the power setting are set to max to the wireless adapter whether i'm plugged in or on battery. Intel can we get a response here?
To quote 'popejustice'
INTEL CAN WE GET A RESPONSE HERE?
Sorry for shouting but sometimes that's the only way to get noticed.
Morning
I have recently purchsed a Samsung laptop (UK version), with Core i5 and the advanced N 6235 driver, and are also experiencing the exact same problem. I have sent the laptop back to Samsung and it came back apparently fixed, however its happening again. Sometimes after 20 mins, sometimes after hours! The wireless will state that it's gone to limited connection and then when you either disconnect to reconnect or trouble shoot, its sends the screen blue with a failure and then disables the Intel N 235 driver. I have no idea what to do next?! How do i also report this problem to Intel? Drivers are upto date also. This problem doesn't happen on any other devices we have on Wifi!
I am also having issues with the Intel N 6235 wireless adapter. I have just purchased a new Samsung NP530U4C laptop with the N6235. It either doesn't connect or drops off after a few minutes, and the only way to reconnect is to restart the computer. I have other laptops in the house that work fine, so it's not the router that is causing the problem. Is there anyway to fix this?
Louisa - I have the same laptop, ive had it a few months now and still i'm getting drop outs. The laptop has even been sent back to Samsung but they returned it stating fixed and no problems, despite me sending all the screen prints of drop outs, fro anything from intel disabled, not enough memory to use etc etc Hope they find a solution soon as its drives me up the wall!
I just bought a Samsung series 5 with the 6235 and this issue is starting to pissing me off. Besides the drops I have less signal power. Even my iPhone 3GS catch more signal power than this.. I think I'm going to return this laptop.
I also bought a series 5 laptop recently, and experience the same problems with the Advanced-N 6235 WiFi card. I constantly have problems connecting to my wireless network, and when I finally have a connection, it drops regularly (streaming is a disaster). I have several other WiFi devices that, without exception, connect to this network without any problems. The neighbors let me test it on their secure network, but with the same connecting problem as result. I discovered that the 6235 has no problems connecting to a non secure network, but only to a secure network. It's clear to me that the problem isn't in my network settings. I hope this problem will be solved soon!
I had the same problem. I think I have a workaround this problem. In my case (samsung series 5 notebook), the wifi card appears in device manager lacking of resources.
Therefore, I released some resources DISABLING the WIRED network card and rebooting computer.
It tooks some minutes the computer updates things and reboot, but after that....WOW you DO have stable wifi access. Of course, the lan port is disabled, but wifi works.
Now the device manager shows several new devices, using other other drivers.
Is a workaround worth trying in the meanwhile of a better solution from Intel.
Best regards
Jaime
I have the same problem. A Samsung 5 Series Ultrabook just 1 month old with this wireless adapter. There seems to be little knowledge of or acceptance of this issue by both Intel & Samsung. The default response is to send it for repair which, as we've heard from marie chapman, is not really going to be the resolution we all seek.
I've downloaded the latest driver but the .exe file won't open or run to update the driver. Wish I'd bought a MacBook now :-(
Same problem with my series 5 samsung ultrabook. WiFi signal is poor, RSSI is 10-15 dB lower then on other laptops. WiDi isn't working, in 2 meters from receiver it shows signal level only 3-4 out of 5, and I even can't watch 720p because sound and video drops and finally it gets disconnected on signal lost.
Here's another one... Having a Samsung np530u3c. Same network problems here, wifi works for only a couple of minutes, then drops and i only get sporadic accecs. Very, very annoying. I also tried the trick to disable LAN-port but that did not help. Any other suggestions? Intel should realy post a reply in this thread on how/what they are doing to figure out this problem!
As everyone else, I'm having the sporadic dropouts on my new Samsung NP550 and am really frustrated. I made the changes in the power management, rolled back the driver to version 15.5.6.48 and let Win8 troubleshoot the connection a billion times. All that didn't make a difference.
Above all, I wasn't able to connect to my router either. This changed when I disabled all the Intel services in the task manager, which I didn't want to do at first as there's more "Intel inside" than just the buggy 6235 card. The internet connected straight away and I was able to connect to my router again. So far, I'm still connected (will see for how long).
The same problem on Samsung np530u3c. Turning off 802.11n in driver settings helps but I it's just not good workaround. I hope to see driver bug fix or at least official reply.
