Wireless
8781 Discussions
TWT (Target Wake Time) function issue on Intel(R) Wi-Fi 6 AX210 160MHz
SravaniS
Hi Intel Team,
I want to test TWT functionality on Intel(R) Wi-Fi 6 AX210 160MHz module, Here are the two cases i have checked
1.using Intel AX210 with 6.1 kernel as Station and Dell latitude 5430 laptop which has Intel AX211 network adapter as AP(Acess Point),
AX210 module is connected to Ax211 AP on WIFI6
but in the Probe Request broadcast Frame, TWT Requester support and TWT Responder Support bits are disabled
Why TWT Requester support bit is disabled from ax210 broadcast frame?
2. Using intel ax210 as Staion and Ublox JODY-W3 as AP, Ublox is providing WIFI6 AP with hostapd configuration
Intel ax210 is not connecting to Ublox AP, also used the command "iw dev wlan0 scan | grep -E 'SSID'" to scan available WIFI SSIDs, Ublox SSID is not even listed here while the other SSIDs shared from laptop/mobile are listed
Why is Intel AX210 not connecting to Ublox AP and how to test TWT functionality in this case
Jocelyn_Intel
Hello, @ico31
Thank you for posting on the Intel® communities.
I understand that you are having code 14 errors. I will do my best to assist you here.
Please, answer these questions to have a better perspective on this issue:
  1. Is the Intel® Wi-Fi 6E AX210 the pre-installed Wi-Fi card in your laptop or is it an integration (upgrade/ not the original card)?
  2. Was it working fine before?
Jocelyn M.
SravaniS
-> Intel® Wi-Fi 6E AX210 Wi-Fi, REV=0x420 module is connected to imx over pcie slot
-> It(AX210 as Station) was connecting to Dell laptop with AX211 Wi-Fi Card(as AP) on Wi-Fi 6E , TWT Requester Support bit was not set with 6.1 kernel
It was never connected to Ublox AP
Jocelyn_Intel
Hello, @ico31
Thank you for the information provided.
I will do some research on this. As soon as I have updates, I will get back to you.
Jocelyn M.
Jocelyn_Intel
Hello, @SravaniS
Thank you for your time.
In order to continue investigating, May we know what project is your company working on (via TWT function)?
How many systems do you plan to ship with Intel® Wi-Fi 6E AX210 as STA, and as AP?
Jocelyn M.
Jocelyn_Intel
Hello, @SravaniS
I hope you are great.
I am checking this thread and I would like to know if you were able to check my previous post.
Jocelyn M.
Jocelyn_Intel
Hello, @SravaniS
I hope you are doing great.
As we have not heard back from you, we will proceed to close this thread now.
If you need any further assistance, please feel free to contact us back and submit a new question as this thread will no longer be monitored.
Jocelyn M.
