I usually get around 2 - 10 mb download speeds when all the other devices in my room get more than 150. the wifi icon on my taskbar only shows 2 bars when i should be getting full.
This sounds more like an antenna issue that anything else. I suggest that you check to see that the two antenna wires are firmly connected to the WiFi card and, if a laptop, that the antenna lead has not been crimped by the hinge mechanism.
Hope this helps,
I am pretty sure they are firmly connected
Hello scary276,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your Intel® Wi-Fi 6 AX200 (Gig+).
1. Are you using a laptop or desktop computer? What is the model of the laptop or motherboard (if desktop)?
2. Is this the original adapter that came pre-installed on your computer or did you change/install the adapter to this one?
3. Do you see any error in teh device manager?
4. What is the BIOS version?
5. What is the operating system installed as well as the version and build?
6. Is the issue present in both bands (2.4GHz and 56GHz)?
Deivid A.
1. It is a desktop, the motherboard is an asus prime a520m-e
2. This the original adapter that came with the computer.
3. No, there are no errors.
4. My BIOS version is American Megatrends Inc. 2803, 27/04/22
5. Windows 11 Home, 22H2, the build is 22621.1702
6. It is persistent in both bands
edit: I switched the bands to 5GHz and it seems to be working fine for now, it used to be persistent in both bands tho.
Its not letting me edit but its starting to be slow again. sometimes its around 50-60mb and the wifi has full bars on the taskbar. and sometimes only 2 bar and around 8-16mb.
Hello scary276,
Thanks for the confirmation. Based on the information provided, please try the following:
1. Get in contact with Asus to confirm the proper steps to update your BIOS to the latest version (3002).
2. Make sure that you have performed all the Windows updates, including the optional ones.
3. Perform a clean install of the Intel drivers.
- Driver: https://www.intel.com/content/www/us/en/download/19351/windows-10-and-windows-11-wi-fi-drivers-for-intel-wireless-adapters.html
- Steps: https://www.intel.com/content/www/us/en/support/articles/000022173.html
4. Try the "Recommended Settings for 802.11ax Connectivity":
Deivid A.
Hello scary276
After checking your thread, I would like to know if you need further assistance.
If so, please let me know.
Deivid A.
Hello scary276,
I was checking your thread and see that we have not heard back from you.
I’m going to close your post, but if you need further assistance, please do not hesitate to create a new thread.
Deivid A.
