Wireless
8661 Discussions
Upgrading Notebook (Fujitsu Amilo Pi3560) with Intel AC-7260HMW?
HSche4
i plan to upgrade my notebook (Fujitsu Amilo Pi3560) with the Intel AC-7260HMW WIFI-card.
Does this card work with the buildin antenna?
Is it possible to use the AC-standard?
The origin WIFI-card of the notebook is an RTL8191SE (b/g/n).
Thank you very much!
ASouz7
Hello Memurubo,
We understand you want to change the wireless adapter on your computer. However, it is important that you know that Intel does not support integrations, which is when you change the original adapter that comes already installed in your computer for another one. We always recommend that you contact the manufacturer of your computer for further information on such action to make sure you will achieve your goal. Please consider that wireless hardware installation and use is subject to regulatory approval and the adapter of your interest may not be supported by your computer model. Only your system manufacturer is entitled to provide the list of validated and certified adapters that are compatible with your system.
Furthermore, Intel wireless adapters for laptops are meant to be professionally installed by the Original Equipment Manufacturer (OEM) technicians on certified systems only. With that being said, we suggest you to carefully read the information in the links below and then, contact your computer manufacturer.
http://www.intel.com/support/wireless/wlan/sb/CS-031167.htm http://www.intel.com/support/wireless/wlan/sb/CS-031167.htm
http://www.intel.com/support/wireless/wlan/sb/cs-011644.htm http://www.intel.com/support/wireless/wlan/sb/cs-011644.htm
Let us know if this helped you.
