Hello!
Asus motherboard with wifi6 ax201 adapter installed. When using a computer as a wifi access point, I cannot select the parameters corresponding to wifi6. Сan you help with configuring the module for 5 Hertz transmission.
Dauletov, Thank you for posting in the Intel® Communities Support.
In order for us to provide the most accurate assistance on this matter, we just wanted to confirm a few details about your system:
What is the model of the motherboard?
If this is a laptop, what is the model of it?
Is this a new computer?
Was it working fine before?
When did the issue start?
Did you make any recent hardware/software changes?
The wireless card, did you purchased it separately or did it came installed on the computer?
Which Windows* version are you using?
Does the problem happen at home or work environment?
Please provide the SSU report so we can verify further details about the components in your platform, please check all the options in the report including the one that says "3rd party software logs":
Albert R.
Hello Dauletov, I just wanted to check if you saw the information posted previously and if you need further assistance on this matter?
Albert R.
Hello Dauleto, Since I have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Albert R.
