Wireless
8617 Discussions
Weak signal "Intel(R) Dual Band Wireless-AC 3168".
EdeGu2
I'm in a room with many devices and most seem to connect fine to our Google Wifi router. Anything I can do to hopefully make the connection table. The wifi signal seems to be fluctuating as well.
C:\Users\EsthetixPC>netsh wlan show interface
There is 1 interface on the system:
  Description      : Intel(R) Dual Band Wireless-AC 3168
  GUID          : 7d34b357-629d-4255-bd75-3a2ef6135048
  Physical address    : c8:09:a8:8b:95:9d
  State         : connected
  SSID          : Esthetix-G
  BSSID         : 08:9e:08:ef:63:93
  Network type      : Infrastructure
  Radio type       : 802.11ac
  Authentication     : WPA2-Personal
  Cipher         : CCMP
  Connection mode    : Auto Connect
  Channel        : 149
  Receive rate (Mbps)  : 29.3
  Transmit rate (Mbps)  : 29.3
  Signal         : 38%
  Profile        : Esthetix-G
  Hosted network status : Not available
n_scott_pearson
38% is pretty low signal strength. Are you sure that the antennas are properly connected to the card? Some laptops have better rates with their primary antenna versus their secondary. Could you possibly have swapped them?
