Wireless
8630 Discussions
What network card would be a good replacement for a AC3168? 802.3
perrynpat
What network card would be a good replacement for an Intel Dualband Wireless AC3168 network Card? Please do not say "Another Intel Dualband Wireless AC3168 network Card" TIA
n_scott_pearson
Provided you device manufacturer sees no issues - or you just decide to proceed hoping it will work (it should) - you have a number of choices available to you:
  • If you want to stay with WiFi 5 and Wireless-AC, you can use the 9260 module (look for Intel 9260NGW).
  • If you want to upgrade to WiFi 6 and Wireless-AX, you can use the AX200 module (look for Intel AX200NGW).
  • If you want to upgrade to WiFi 6e and Wireless-AX, you can use the AX210 module (look for Intel AX210NGW).
Note: Do not attempt to use 9560, AX101, AX201, AX203, AX211 or AX411 modules; they will not work in the standard M.2 connector that you have on your motherboard.
Hope this helps,
AlHill
You need to consult with your device manufacturer for compatibility and integration.
n_scott_pearson
Hope this helps,
Jocelyn_Intel
Hello, @perrynpat
I am glad to see that fellow community members have the knowledge and they jumped in and helped.
It is worth mentioning that Intel does not support wireless integrations (installing a different wireless adapter into your system/laptop). We recommend you speak to the Manufacturer of your equipment for support on wireless integrations and replacement parts to ensure compliance with the regulatory requirements of your country and support. It is important to check for compatibility with the System Manufacturer, as there could be certain cards that will not work with the system.
For more information, read the following article under the title "Regulatory Information Regarding Wireless Hardware Installation or Upgrade."
Please, keep in mind that this thread will no longer be monitored by Intel. Thank you for your understanding.
Jocelyn M.
