Wireless
8663 Discussions
Where is the maximum speed 866Mbps on the latest drivers for Intel 7260 and 8260?
DBelo
Hi all,
I have a problem with the speed of the connection with the router on adapters AC7260 and AC8260
The router TP-Link Archer c7 AC1750
Laptop with OS Windows 10 x64
My old adapter Intel® Dual Band Wireless-AC 7260 with the old drivers ver. 17.13.11 are always connected with router at speed 866Mbps.
In this version of the drivers, it also established a very handy utility for monitoring the network from Intel PROSet Enterprise.
I discovered that this utility is absent, and the maximum speed of connection with the router only 300Mbps if upgrading to the latest drivers 18.40.4.
My new WiFi adapter Intel® Dual Band Wireless-AC 8260 with all drivers from Intel site is connected only with the speed of 300Mbps.
If I try to install the old driver software is installed, including the Intel PROSet Enterprise, but the driver on the adapter in the absence of a system.
If I install later the latest driver, then Intel PROSet Enterprise or completely removed from the computer, or is not working properly, and writes "Driver not installed", but in any case a connection is established at 300Mbps.
How do I get the stated rate of the latest drivers for 8260 and 7260?
Hello MonDee,
The theoretical maximum of 867 Mbps is enabled by 802.11ac using 2 spatial streams, however, the information you provided suggests that your Intel® Dual Band Wireless-AC 8260 is negotiating a 802.11n connection, not 802.11ac.
The connection is a result of the router, OS, computer and adapter combination. The main things you can check for this are the following:
- Obtain the driver from the http://www.intel.com/content/www/us/en/support/topics/oems.html Computer Manufacturer Support. As second option, use the one from https://downloadcenter.intel.com/ Intel® Download Center.
- Go the Device Manager and apply the configuration from the following advisory: http://www.intel.com/content/www/us/en/support/network-and-i-o/wireless-networking/000005544.html http://www.intel.com/content/www/us/en/support/network-and-i-o/wireless-networking/000005544.html
- Make sure your Windows* OS has any relevant system updates and that your Motherboard BIOS is up-to-date as well.
It is also important to mention that the Intel® PROSet/Wireless WiFi Connection Utility is not available in Windows® 10, since the wireless connections are handled by the OS.
JB
We did not receive any reply to our previous post. Please let us know if have any additional questions about this matter.
JB
