Why cant I see my wifi6 network? I have a Nighthawk RS300 router with an Intel AX201. The router admin page shows the wifi 6 network is enabled. The adapter settings show enable AX mode enabled. However in the wifi list only the 2.4 and 5g is shown. There should be a 3rd separate network for wifi 6 according to the router admin page. Adapter drivers are updated.
Hope this explains it,
Hi Colinski585,
Dean R.
Hi Colinski585,
Dean R.
Hi Colinski585,
This is due to 6GHz support required OEM manufacturer validation and approved its compatibility with 6 GHz, since @n_scott_pearson shared Wi-Fi 6E and Wi-Fi 7.
You may refer to this link for reference:
Intel® Wi-Fi 6E AX210 Adapter Cannot Connect to a 6 GHz Band
Dean R.
