On our proprietary GT10 platform we have recently changed from AC 7265 to AC 8265. And noticed the AC 8265 does not drive the Wi-Fi or Bluetooth LEDs. Is this expected behaviour?
Hello LCopp
Thank you for contacting our Intel® communities.
I understand that you upgraded from Intel® Wireless-AC 7265 to Intel® Dual Band Wireless-AC 8265 in your GT10* platform.
After that, you are experiencing issues with the Wi-Fi/Bluetooth LEDs, right?
May we ask, how did you update the drivers on the unit?
Does the unit have an operating system?
I hope this helps.
Diego S.
Intel (R) Customer Support Technician
Under Contract to Intel (R) Corporation
Hi Diego
The GT10 is our own Android product and we write our own software.
We are using Linux 4.1 with the latest drivers from the iwlwifi-backport and firmware from linux-firmware repositories.
The AC 8265 works fine but the LEDs don’t illuminate
thanks
Lee Coppins-Brown
Hardware Design Team Leader
[cid:GrosvenorLogo-Email_d799078f-7af7-4f27-91b2-4645db169958.png]<http://www.grosvenortechnology.com/>
Unit S, The Fulcrum Centre, Vantage Way
Poole, Dorset, UK, BH12 4NU
Phone +44 1202 627 618
Grosvenor Technology will close for Christmas on the 24th December at 15.00 and will re-open on the 2nd January at 9:00. We wish all our suppliers, customers and partners a peaceful and restful festive period.
website<http://www.grosvenortechnology.com/> | map <https://www.google.com/maps/place/Endeavour+House,+London+Stansted+Airport,+Stansted+Airport+%28STN%29,+Coopers+End+Rd,+Stansted,+Essex+CM24+1AL,+UK/@51.8796903,0.2489049,15z/data=!4m2!3m1!1s0x47d88e4f40335f69:0xbcfadf9a88d94754?hl=en>
This email may contain confidential and/or private information. If you received this email in error please delete and notify sender. Grosvenor Technology Ltd is a limited company registered in England and Wales. Company registration no. 2412554. Registered office: 91 Wimpole Street, London, W1G 0EF, United Kingdom.
Hello LCopp
Thank you for your response.
In this case, Intel (r) has not tested and validated Intel® NUC on your Linux version, we know that other customers have successfully installed it.
With this being said, the issue that you are experiencing (no lights) might be related to wireless drivers and is totally expectable , as the only drivers available for your unit work on Windows* as you can check here :
https://www.intel.com/content/www/us/en/support/articles/000005602/network-and-i-o/wireless-networking.html
Intel suggests you check your Linux distro's website and forums for peer assistance with this driver issue installation issue.
I hope this helps.
Diego S.
Hello LCopp,
We just wanted to double check if you were able to contact your Linux distro.
Please don’t hesitate on contacting us back.
I hope to hear from you soon.
Diego S.
Hello LCopp,
We just wanted to double check if you were able to contact your Linux forum?
Diego S.
Hi Diego
Thanks for your email.
No we haven’t made any progress on this. Our software team advise we are using the latest Linux drivers but the AC8265 LEDs don’t function (whereas they were ok on AC7265)
Unfortunately we don’t have time to investigate this further, the LEDs are not visible when the AC8265 is in our product so for the time being we will use it without the LEDs operating
Lee Coppins-Brown
Hello LCopp,
Thank you your response.
In this case, let me ask :
Can you install the Intel® Dual Band Wireless-AC 8265 in another system (with a supported OS)?
Most likely the culprit of the issue is coming from the missing drivers, so by installing the unit in another OS we can isolate the issue.
Diego S.
Hello LCopp,
We just wanted to double check if you were able to install another OS?
Diego S.
Hello LCopp,
We just wanted to double check again if you were able to install another OS?
Diego S.
Hello LCopp,
I was checking your case and I would like to know if you still need help?
Please do not hesitate in replying to this email.
You can also contact us through our phone support line 916-377-7000 Monday thru Friday 8 – 5 PST or you can provide us a call back number and the best time within our support hours so we can contact you and provide you with the assistance needed by phone.
We are currently closing your case as we have not heard anything back from you, however it will remain active.
Diego S.
Topic Options
