Wireless
8716 Discussions
Wi-Fi 6 AX200 160MHz, i can only use the 21.40.2.2 driver
shork
My computer is a thinkpad p1 Gen2 , the network card is Wi-Fi 6 AX200 160MHz
I can only use the 21.40.2.2 driver and when I upgrade it to version 22 or the latest 22.70 driver using windows auto update it reports an error of.
Events:
Event id 5005: TX/CMD timeout (TfdQueue hanged).
Intel(R) Wi-Fi 6 AX200 160MHz : Has encountered an internal error and has failed
These errors keep repeating and making my system lag and disconnect
Now I'm afraid to upgrade my Windows system because it will make my computer not work properly after upgrading the AX200 driver to version 22
David_G_Intel
Hello shork
Thank you for posting on the Intel️® communities. Please share more information with us:
  • Does this happen with the Intel drivers only or do you also get problems with Lenovo's drivers?
  • Do you get Bluetooth issues?
  • When did it start to happen?
  • Is this a new computer? If so, have check with your system's OEM for validated drivers or support on known issues related to the symptoms experienced?
  • What OS version are you using?
  • Is this the original adapter that came pre-installed in your system or have you changed/installed a new adapter recently?
  • Were you able to have you wireless connection in a normal/expected performance before?
  • Have you installed any recent software or hardware in your system?
  • Have tried a roll back to a previous driver version for testing?
  • Intel® System Support Utility (Intel® SSU) results
David G
David_G_Intel
David G.
David_G_Intel
David G.
