Wireless
8782 Discussions
Wi-Fi 6 AX200 cannot open the 5G frequency band for hotspot use
DavidTseng
Wi-Fi 6 AX200 product, using ubuntu 20.04 LTS operating system, using the third-party software hostapd recommended by Intel for management, only 2.4G frequency band can be turned on, 5G frequency band cannot be turned on, how to configure to turn on 5G frequency band, and 2.4 G can be used at the same time. Thank you!
OS version screenshot
lspci
Third-party software hostapd version:
hostapd 5G configuration file
wifi驱动版本:https://github.com/intel/backport-iwlwifi
Iw list command to view the supported frequency bands in ap mode:
The firmware version used by wifi:
./hostapd -d hostapd.conf run error
Can you help me determine what caused this error problem, thank you very much!
Alberto_Sykes
DavidTseng, Thank you for posting in the Intel® Communities Support.
In reference to your inquiry, please try the following troubleshooting steps in order to determine if there might be a problem with the Wireless configuration:
WiFi troubleshooting steps
Step 1: Check whether the kernel version supports this device:
The reference table of Wireless adapters and corresponding kernel versions is available in the following link:
https://wireless.wiki.kernel.org/en/users/drivers/iwlwifi
The latest FWs are available by the following link:​
https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/
If the kernel version corresponds to the Wireless adapter, proceed with step 2.
Step 2: Check whether the Wireless adapter is connected correctly:
Type the following command to the terminal: # lspci​
Verify that the Intel network controller ​is identified, as on a picture below. If not, then the system doesn't identify the Intel networidentifyk adapter and you will need to make sure it's properly integrated. You may need to request help from the system manufacturer. If the wireless adapter is properly identified - proceed with the step 3.
Step 3: Check whether this is an iwlwifi issue:
Type the following command to the terminal: # modinfo iwlwifi​ (example of the command output is on the picture below). If there is no output, then the module isn’t installed this is the distribution installation issue.
Please type: # lsmod | grep iwlwifi​
If the result is empty, the driver hasn't been loaded. Most likely to be a distribution issue.
To verify, please type: # dmesg | grep iwlwifi​
If the result is empty, the driver wasn’t initialized and this is a distribution issue. If the result is populated as on the above picture, proceeed with the step 4.
Step 4: Check whether the suitable firmware is installed:
Please type: # dmesg | grep “no suitable firmware found!”​
If the result is not empty, it means you don’t have a suitable FW (api mentioned in the dmesg).
Please visit here​ https://wireless.wiki.kernel.org/en/users/drivers/iwlwifi for supported FW, or here​ ​https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/ for the latest versions.
If these steps didn't reveal the issue or didn't solve the problem, proceed with the Step 5:
Step 5: Collect the debug data:
Please type: # dmesg | grep ASSERT​
If the output is empty, please follow this wiki: https://wireless.wiki.kernel.org/en/users/drivers/iwlwifi/debugging to extract dmesg and trace-cmd.
If the output has value, please collect from the wiki FW dump too.
Albert R.
A Contingent Worker at Intel
DavidTseng
The following is a screenshot of the operation according to your steps, please help to see why there is no 5G signal?
step 1:   uname -a
step2:   lspci
step3:   modinfo iwlwifi
    step 4: dmesg | grep "no suitable firmware found!"
   step5: dmesg | grep ASSERT
The 5G frequency band still cannot be turned on. Could you tell me where it is not configured? Which version of the operating system Intel is compatible with?
Alberto_Sykes
DavidTseng, Thank you very much for providing that information.
In reference to your question, we will do further research on this matter, as soon as I get any updates I will post all the details on this thread.
Albert R.
DavidTseng
Thanks for your help!
Yesterday, the step5 of the operation missed the debug operation.
Open iwlwifi debug, but no more information.
cat .config
dmesg | grep wilwifi
Looking forward to your more reply
DavidTseng
Hi Alberto ,
Saw the information from the https://wireless.wiki.kernel.org/en/users/drivers/iwlwifi
Does it mean that only Ap 2.4G mode is supported?
have a nice day!
Alberto_Sykes
DavidTseng, You are very welcome, I just received an update on this matter.
Just to let you know, we are currently still working on your case and in order for us to provide the most accurate assistance on this matter, we just wanted to confirm a few details about your system:
What is the model of the motherboard?
If this is a laptop, what is the model of it?
What is the model of the Router?
Is this a new computer?
Was it working fine before?
When did the issue start?
Did you make any recent hardware/software changes?
The wireless card, did you purchased it separately or did it came installed on the computer?
What is the OS version?
Already using a driver from our Linux driver's site?
Are you using the Intel® desktop kit or just the Intel® Wireless card?
Does the problem happen at home or work environment?
In regard to your question, "Does it mean that only Ap 2.4G mode is supported?", we will confirm if that is the case once we received the information requested on this post, once you get the chance please let us know those details.
Albert R.
DavidTseng
Hi, thanks  for your reply
According to your question above, we have the following reply.
The platform we purchased from Advantech, model: FWA-1212VC.
At the same time got a wireless network card intel Ax 200 from them.
OS version: Ubuntu 20.04, kernel 5.4.0-51.
The firmware and drivers downloaded from the intel official website have not been modified in any way.
If you want to know more details, I am glad to provide you with it.
Alberto_Sykes
Hi DavidTseng, You are very welcome, thank you very much for sharing those details.
We will continue with our research on this matter, as soon as I get more details I will post all the updates in this thread.
Albert R.
Alberto_Sykes
Hello DavidTseng, I just received an update on this matter.
In order for us to continue with our research on this case, we just wanted to confirm:
What is the error message?
How did you enable and test the hotspot?
Did you try enabling 5Ghz frequency via the Run a Command window?
-When the hotspot is enabled, press Alt+F2 to bring up ‘Run a Command’ box, input nm-connection-editor, and hit Enter
-Select and edit ‘Hotspot’. (If you don’t see it, wifi-hotspot is not turned on, go back to step one)
-In the WiFi tab set the Band option accordingly
If by any chance, you are unable to set this up, please provide an image or video and attach it to the thread so we can further assist you with this topic.
Albert R.
DavidTseng
My operating environment is: Ubuntu 20.04, kernel 5.4.0-51, using console mode. Can not operate Alt + F2,  NOWOnly 5G band hotspots can not be used,  while 2.4G band hotspots can be used .
We are very anxious, hurry up and solve it, thank you very much.
DavidTseng
     In the PC  win10 system. Load the latest wireless driver, configure the wireless hotspot, and turn on the 5G frequency band hotspot.
    Tip: "The selected network band is not available. Please select another band and try again".
    The 5G band hotspot still cannot be opened, which is consistent with the performance of Linux.
Alberto_Sykes
Hi DavidTseng, You are very welcome, thank you very much for providing those results.
We will keep working on this matter, as soon as I get more information I will post all the details on this thread.
Albert R.
Alberto_Sykes
Due to regulatory information, we just wanted to confirm in which country the tests that you shared were performed?
Albert R.
Alberto_Sykes
Hello DavidTseng, I just wanted to check if you saw the information posted previously and if you need further assistance on this matter?
Albert R.
DavidTseng
Hi Albert R,
I'm so sorry that  reply question now.
My test environment was conducted in Beijing, China.
Best wishes!
Alberto_Sykes
Hi DavidTseng, No problem at all, thank you very much for clarifying that information.
We will continue with our research on this matter, as soon as I get more updates I will post all the details on this thread.
Albert R.
Alberto_Sykes
DavidTseng, I just received another update on this topic.
For your information, we just wanted to let you know that all 5Ghz in China SKUs are set to Passive, these are not allowed for SoftAP operation by our Intel® NIC and this specific OTP/NVM. That is actually the reason why you cannot open a 5GHz frequency band for the hot spot use.
Albert R.
aktinkon
Hello. Let me join the discussion, thanks.
I have the same problem. AX200 units I am working with were sold to the Ukraine and to US. In both cases all frequencies in Band 2 (5 GHz) are marked as "no IR" or "disabled" according to "iw list" output. May you please tell me in what jurisdiction Intel allows SoftAP operations and how to get this firmware?
WBR, Oleksii
bamhm182
I'd also like to post on this to see if anyone comes across a fix. When in Windows 10, I can create a 5GHz mobile hotspot without a problem. When in Linux, I'm getting `no IR`, `radar detection`, and/or `disabled` on all 5GHz channels, which results in hostapd not being able to create a 5GHz AP.
I am using the following system in the US:
Motherboard: ASUS Zenith II Extreme Alpha
CPU: AMD ThreadRipper 3970X
If there's anything I can do to help figure this out, please let me know.
jpereira
I'm facing the same problem. I bought this module specifically for using in AP mode and I cannot get it to work.
I'm using Debian Buster with kernel 5.4.73. I have the AX200 card installed on an ASUS J4105-ITX motherboard.
I bought the AX200 in Sweden at Mouser.se (probably shipped from USA).
There are many people facing the same problem on internet: The board can only work in AP mode on 2.4GHz network. Nobody seems to be able to fix the issue and the general recommendation is to throw the intel module on the trash and buy a Qualcomm Atheros module.
I tried to compile the drivers from source, the kernel, and hostapd without success on fixing the issue.
Apparently, for what I could find, this module is "self managed" and this can be seen when running:
$ sudo iw reg get
global
country SE: DFS-ETSI
(2400 - 2483 @ 40), (N/A, 20), (N/A)
(5150 - 5250 @ 80), (N/A, 23), (N/A), NO-OUTDOOR, AUTO-BW
(5250 - 5350 @ 80), (N/A, 20), (0 ms), NO-OUTDOOR, DFS, AUTO-BW
(5470 - 5725 @ 160), (N/A, 26), (0 ms), DFS
(5725 - 5875 @ 80), (N/A, 13), (N/A)
(57000 - 66000 @ 2160), (N/A, 40), (N/A)
phy#3 (self-managed)
country 00: DFS-UNSET
(2402 - 2437 @ 40), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS, NO-80MHZ, NO-160MHZ
(2422 - 2462 @ 40), (6, 22), (N/A), AUTO-BW, NO-80MHZ, NO-160MHZ
(2447 - 2482 @ 40), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS, NO-80MHZ, NO-160MHZ
(5170 - 5190 @ 160), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS
(5190 - 5210 @ 160), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS
(5210 - 5230 @ 160), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS
(5230 - 5250 @ 160), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS
(5250 - 5270 @ 160), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS
(5270 - 5290 @ 160), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS
(5290 - 5310 @ 160), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS
(5310 - 5330 @ 160), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS
(5490 - 5510 @ 240), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS
(5510 - 5530 @ 240), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS
(5530 - 5550 @ 240), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS
(5550 - 5570 @ 240), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS
(5570 - 5590 @ 240), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS
(5590 - 5610 @ 240), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS
(5610 - 5630 @ 240), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS
(5630 - 5650 @ 240), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS
(5650 - 5670 @ 80), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS, NO-160MHZ
(5670 - 5690 @ 80), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS, NO-160MHZ
(5690 - 5710 @ 80), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS, NO-160MHZ
(5710 - 5730 @ 80), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS, NO-160MHZ
(5735 - 5755 @ 80), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS, NO-160MHZ
(5755 - 5775 @ 80), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS, NO-160MHZ
(5775 - 5795 @ 80), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS, NO-160MHZ
(5795 - 5815 @ 80), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS, NO-160MHZ
(5815 - 5835 @ 20), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS, NO-HT40PLUS, NO-80MHZ, NO-160MHZ
Here we can see that my system is set to Sweden (country SE: DFS-ETSI), but the card is unset (country 00: DFS-UNSET). Since the module is unset it doesn't allow AP mode using 5GHz because the module doesn't know what are the channels it can use to initiate radiation on my region.
Apparently, the module should scan my neighbors networks and based on the results it would know where it is located and set the region automatically, correct me if this is wrong because I couldn't find a good explanation for this. It would also mean that if I'm far from the city this module wouldn't work...
I also tried to use the module option "lar_disable=1" when loading the iwlwifi module:
modprobe iwlwifi lar_disable=1
The module option "lar_disable=1" should disable LAR (Location Aware Regulatory) which I think has to do with disabling the self managed mode, but even with this option the module reports NO-IR (no initiate radiation) for 5GHz channels, it seems to work on older intel modules. Since lar_disable is being dropped (https://bugzilla.kernel.org/show_bug.cgi?id=205695#c6) in more recent kernels we shouldn't rely on it anyway.
So, the problem seems to be in how make the module "discover" where it is located. How can we trigger it?
Please give a solution for this,
BR,
JP
