Wireless
8116 Discussions
Wi-Fi 6 AX201 // Ubuntu 22.04
Alexdxc
i have an issue with Intel wifi drivers on ubuntu 22.04.
Can you help me ?
So, i have an Wi-Fi 6 AX201 160MHz adapter.
lshw -c network
  *-network
       description: Network controller
       product: Wi-Fi 6 AX201 160MHz
       vendor: Intel Corporation
       physical id: 14.3
       bus info: pci@0000:00:14.3
       version: 01
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix bus_master cap_list
       configuration: driver=iwlwifi latency=0
       resources: iomemory:600-5ff irq:16 memory:6001124000-6001127fff
dmesg shows, that AX101 is found -
iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6 AX101, REV=0x351
and fails with error -
[    5.570832] iwlwifi 0000:00:14.3: Loaded firmware version: 48.13675109.0 QuZ-a0-hr-b0-72.ucode
[   21.507898] iwlwifi 0000:00:14.3: Failed to start RT ucode: -110
[   21.507901] iwlwifi 0000:00:14.3: Collecting data: trigger 16 fired.
[   28.210078] iwlwifi 0000:00:14.3: Failed to run INIT ucode: -110
[   28.221794] iwlwifi 0000:00:14.3: retry init count 2
Linux name-U59 6.2.8-060208-generic #202303220943 SMP PREEMPT_DYNAMIC Wed Mar 22 13:50:04 UTC 2023 x86_64 x86_64 x86_64 GNU/Linux
rfkill list all
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
I have tried different kernel versions, drivers from your web but still no success.
