Wireless
7424 Discussions
Wi-Fi adapter not found Wifi 6 AX 200 on Ubuntu 21.04
Bumblebee
Hi!
I bought a computer and installed Ubuntu 21.04 (kernel >5.1 as asked by the AX200), everything works fine, including bluetooth, but I get the message: "Wi-Fi Adapters not found".
When I run lshw-C network I get network unclaimed
Product: Realtek etc...
I have read that it may be a firmware problem but I'm not sure if it's that and I'm new to Linux so I don't want tomess anything up...
Any help will be greatly appreciated,
D
DeividA_Intel
Hello Bumblebee,
1. The brand and model number of your system. You can also provide the Intel® System Support Utility for the Linux* Operating System for more details: https://downloadcenter.intel.com/download/26735/Intel-System-Support-Utility-for-the-Linux-Operating-System
2. Is this the original adapter that came pre-installed on your computer or did you change/install the adapter to this one?
3. Have you update your drivers and BIOS?
4. Did you noticed the issue after a system update?
5. Run the following commands and send us the outcome:
· modinfo iwlwifi > If there is no output, then the module isn’t installed this is the distribution installation issue.
· lsmod | grep iwlwifi > If the result is empty, the driver hasn't been loaded. Most likely to be a distribution issue.
· To verify, please type: dmesg | grep iwlwifi > If the result is empty, the driver wasn’t initialized and this is a distribution issue. If there is a result populated, proceed with the next step.
· dmesg | grep “no suitable firmware found!” > If the result is not empty, it means you don't have a suitable FW (API mentioned in the dmesg).
· Please visit here: https://wireless.wiki.kernel.org/en/users/drivers/iwlwifi for supported FW, or here https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/ for the latest versions.
6. If the above steps don't work, collect the debug data:
Type: dmesg | grep ASSERT
If the output is empty, please follow this wiki: https://wireless.wiki.kernel.org/en/users/drivers/iwlwifi/debugging to extract dmesg and trace-cmd.
If the output has value, please collect it from the wiki FW dump too.
Deivid A.
Bumblebee
Hello Deivid,
Thank you for your response. Here is the information you ask for:
It is a hp pavilion ec2013ns. The only thing I did wac change the OS from FreeDOS to Ubuntu 21.04. Didn't touch anything else.
  • modinfo iwlwifi: Saved in txt file
  • lsmod | grep iwlwifi: No output
  • dmesg | grep iwlwifi:  dmesg: read kernel buffer failed: Operation not permitted
  • The rest of the commands give: dmesg: read kernel buffer failed: Operation not permitted
What does this mean?
I also asked in askubuntu, and the person who helped me reached the conclusion that for some reason I don't have the AX-200 since when introducing this command:
lspci -nnk | grep 0280 -A3
I get this:
03:00.0 Network controller [0280]: Realtek Semiconductor Co., Ltd. Device [10ec:8852] DeviceName: Realtek Wireless LAN + BT Subsystem: Hewlett-Packard Company Device [103c:88e1] 04:00.0 Non-Volatile memory controller [0108]: Sandisk Corp WD Black SN750 / PC SN730 NVMe SSD [15b7:5006]
Thank you very much for your help!
D
DeividA_Intel
Hello Bumblebee,
Thanks for the information provided.
Seems to be that the file attached is not from the Intel® System Support Utility, since it does not contain any information about your system. I will appreciate it if you can run the Intel® System Support Utility more time and attach it.
Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
· Download the Intel® SSU and save the application on your computer:  https://downloadcenter.intel.com/download/26735/Intel-System-Support-Utility-for-the-Linux-Operating-System
· Open the application, check the "Everything" checkbox, and click "Scan" to see the system and device information. The Intel® SSU defaults to the "Summary View" on the output screen following the scan. Click the menu where it says "Summary" to change to "Detailed View".
· To save your scan, click Next and click Save.
Deivid A.
Bumblebee
Finally we discovered (thanks to the forum Askubuntu: https://askubuntu.com/questions/1352260/wifi-adapter-not-found-realtek-10ec8852-on-ubuntu-21-04) that the Wi-Fi card provided was in fact not Intel, but Realtek. The vendors are checking where the mistake originated.
Thank you very much for your support,
D
DeividA_Intel
Hello Bumblebee,
Thanks for the update,
I do appreciate the information provided and recommend you to check with Realtek for further support if needed. If you encounter any issue with an Intel product, do not hesitate to let us know.
Deivid A.
