SSU output is attached. Installation fails for Intel Dual Band Wireless-AC 8265. Windows Update had attempted to install and failed, rendering the wireless adapter unusable. Subsequent attempts to repair the installation manually, including by installing WiFi_21.80.2_Driver64_Win10.exe directly as well as using the automated tool, were unsuccessful with the message "A fatal error occurred during installation".
SSU output is attached and key section excerpted below.
Driver I attempted to install both automatically and manually:
https://downloadcenter.intel.com/download/29455/Windows-10-Wi-Fi-Drivers-for-Intel-Wireless-Adapters
Wireless Network Card:
https://downloadcenter.intel.com/product/94150/Intel-Dual-Band-Wireless-AC-8265
Excerpt from SSU output related to failed installation:
Installation Failure: Windows failed to install the following update with error 0x80070002: Intel - net - 20.70.16.4.
Intel(R) Dual Band Wireless-AC 8265 : The network adapter has returned an invalid value to the driver.
Intel(R) Dual Band Wireless-AC 8265 : The version number is incorrect for this driver.
Intel(R) Dual Band Wireless-AC 8265 : Could not allocate the resources necessary for operation.
The system firmware has changed the processor's memory type range registers (MTRRs) across a sleep state transition (S4). This can result in reduced resume performance.
Miniport Intel(R) Dual Band Wireless-AC 8265, {cf513eb2-3d99-424e-a6ed-792b78d82245}, had event Network Interface deleted while PNP Device still exists. Note that this event is provided for informational purpose and might not be an error always (Eg: In case of vSwitch which was recently un-installed or a LBFO team was removed)
Have you tried something like this? If not, try it.
- Download both the Wireless and Bluetooth installation packages to the unit.
- Disconnect from Internet or completely disable Windows Update.
- Uninstall the existing Wireless and Bluetooth packages.
- Reboot (keeping Internet disconnected or Windows Update disabled).
- Install Bluetooth package (before Wireless).
- Install Wireless package (after Bluetooth).
- Reconnect Internet or enable Windows Update.
- Reboot.
- Test.
Hope this helps,
