Wireless
8286 Discussions
WiFi 7 Intel BE200 MLO support
HsinBo
Hello Support Team,
I want to raise an issue of Intel WiFi 7 NIC model BE200, which already with the latest driver version 23.100.0.4, OS: windows 11 24H2.
I have an enterprise WiFi 7 access point and configure the MLO SSID for WiFi7 clients' connection.
The MLO SSID is configured with Tri-band - 2.4GHz + 5GHz + 6GHz.
My BE200 always only use 2 of the 3 bands to connect to the MLO SSID, never launch Tri-Band connection. (Capture the wireless packet of the rest band which not connect, and check that the BE200 even not send the associate request wireless frame to the Access point)
P.S. I have tried several driver versions, totally not work, either.
Please kindly help to tell if this is the driver design (maybe considering power-saving, avoid NIC operates in a high temperature? ) or hardware limitation that at most uses 2 bands to connect in MLO SSID association? or this is a driver bug...?
Please provide an official response for this topic, thank you for your support.
Regards.
HsinBo
VonM_Intel
Hi, HsinBo.
Thank you for posting in our Community.
I understand that you are experiencing an issue with the Intel WiFi 7 NIC model BE200, which is currently running the latest driver version 23.100.0.4 on Windows 11 24H2.
I will investigate this issue further to determine the root cause. In the meantime, I'd like to gather more details, such as the RAM, the exact model of your device, and any system errors that might assist in my investigation. Using the Intel SSU tool will allow us to collect comprehensive information about your system setup, which could help in identifying the underlying cause of this issue.
Thank you for bringing this to our attention.
Have a nice day!
Von M.
VonM_Intel
Hi, HsinBo.
Von M.
HsinBo
Hi Von,
Thank you for looking into this issue.
I’ve attached the information you requested in this comment.
However, I believe the problem may not be related to the OS or my laptop model, so the attached SSU result may not significantly assist in diagnosing this case.
Additionally, I think it should be possible to fully reproduce the symptom in your local lab by connecting to any WiFi 7 access point.
If possible, I would also appreciate it if you could consult the developer RD team to provide details about how the Intel wireless card MLO works. Specifically, I’m interested in understanding why tri-band functionality is not supported, as per my inquiry.
Thank you for your support.
HsinBo
(Virus scan in progress ...)
VonM_Intel
Hello, HsinBo.
I appreciate you for sharing the details and the SSU results. I understand your concerns regarding the relevance of the OS and laptop model in this case. I'll need to investigate the issue further to gather more information about the MLO functionality and the tri-band support limitations on the Intel wireless card.
Once I have updates or any additional insights, I’ll get back to you promptly.
Thank you for your patience and collaboration.
Von M.
HsinBo
Hi Von,
I'll await for your update.
HsinBo
VonM_Intel
Hello, HsinBo.
Thank you. I appreciate your patience, and I’ll provide updates as soon as I have more information.
Von M.
VonM_Intel
Hello, HsinBo.
After reviewing the specifications of your computer, it appears that Wi-Fi 7 is not supported by your system. Just to confirm, have you already contacted HP to confirm whether the hardware is compatible with Wi-Fi 7 and to inquire if there are any firmware updates or hardware limitations that may affect the functionality of the Intel Killer WiFi 7 BE1750 card? Additionally, could you please let us know if you have replaced the pre-installed wireless card in your system? This information could help us better understand the situation.
To assist you further, I would also like to share a helpful article on Regulatory Information Regarding Wireless Hardware Installation or Upgrade, which provides valuable insights into installing or upgrading wireless hardware.
Von M.
HsinBo
Hello Von,
"After reviewing the specifications of your computer, it appears that Wi-Fi 7 is not supported by your system"
I replaced the onboard M.2 wireless NIC with the Intel BE200 and upgraded it to the latest driver version, which was already mentioned in the original post.
Therefore, the laptop model itself is clearly not the issue. As I previously stated, "I do not think the result of SSU provides any useful information."
Furthermore, as noted in my original post, I am able to connect to the MLO SSID broadcast by the Wi-Fi 7 enterprise access point using two bands, it can be 2.4GHz + 5GHz , it can be 5GHz + 6GHz, it can also be 2.4GHz + 6GHz, but never link to tri-band at same time, this is what I reached out Intel here, for provement, please refer to the screenshot below for reference to explain my device with the MLO capability.
It is frustrating that the problem is being attributed to the installed model after your investigation.
As I mentioned before, this symptom should be reproducible 100% of the time. Simply connect to any Wi-Fi 7 AP configured with a tri-band SSID, and the issue should appear. Have you performed this test?
Thank you.
HsinBo
VonM_Intel
Hello, HsinBo.
Thank you for your detailed response and for clarifying the situation further. I sincerely apologize for the frustration this has caused. I completely understand that replacing the M.2 wireless NIC with the Intel BE200 and upgrading the drivers should have resolved any potential hardware-related issues. Your feedback is valuable, and I appreciate your patience in providing that clarification.
In line with that, I will need to do further research on this matter and post the response on this thread once available.
Von M.
HsinBo
Hi Von,
Thank you for checking.
HsinBo
VonM_Intel
Hi, HsinBo.
I appreciate your patience in this matter. Based on the details provided, it seems that your laptop should be compatible with the BE200. However, to ensure full functionality, I recommend checking with the hardware OEM (Original Equipment Manufacturer) to confirm compatibility with your specific laptop model. Additionally, please note that the MLO feature requires certain prerequisites, including the correct operating system (Windows 11), supported access points, an ISP router, and compliance with local country regulations.
Regarding Wi-Fi 7, all Intel® Wi-Fi 7 products support the 6GHz band, but its usage is reliant on Windows 11 OS support. I suggest contacting the OEM directly for further confirmation and to ensure all components are set up for optimal performance.
Von M.
HsinBo
Hi Von,
First of all, my BE200, my Windows version, and my country all support 6GHz. I have clearly stated that I can connect using MLO with 2.4GHz + 6GHz or 5GHz + 6GHz, and I have provided supporting evidence in the form of screenshots showing the MLO link connection.
Thus, I do not understand or accept the conclusion ask me to contacting the OEM vendor. On what basis was it determined?
Have you actually reviewed the information and screenshot I provided?
If you really did, are you mean that MLO could is possible to be partially supported???
Additionally, I have repeatedly requested that you reproduce the symptom on your side, You can use a device you deem as "fully supported" to verify if the BE200 can establish a tri-band connection with a "fullt supported WiFi 7" AP. However, you have never offered response or evidence of testing this yourself.
Instead, you ignored, did nothing then blamed on the customer's device, provide useless investigation result, shift the responsibility again and again.
The original purpose I created the post here is only to get the reason why BE200 cannot launch a TRI-BAND MLO connection to the WiFi 7 AP, I suspect this might due to some reason, I never ask you to make it connect with TRI-BAND, resolve this issue.
In the end, I get nothing from Intel support.
The lack of acknowledgment or testing on your side is both disappointing and unacceptable.
HsinBo
5urg3
I’ve managed to find out a few things
Tri-band MLO with the Be200 is possible on Linux, but not windows for some reason
https://wizardfi.com/wifi7/2024/09/13/three-link-emlsr-mld-mlo-be200-hpe-aruba-networking-ap-735.html
Another thing is that the Be200 doesn’t support MLMR, only EMLSR, so using MLO isn't going to result in any faster speeds, regardless of what bands it’s connecting on
The Intel reps that actually respond to these forum posts are more or less useless.  They are not trained on any of these techs, they probably don’t even know what MLO stands for let alone how it works.  It’s pointless to even post here I think.
The engineers who actually work on these products and have the knowledge to help — don’t seem to be able to post here on these forums.  It’s all just a bunch of low level techs who don’t have a basic understanding of these kinds of advanced topics.
in other words, you and I and just about everybody else on these forums — are wasting our time
