Each time I update my windows to the latest update (Windows 11 Insider Preview 10.0.25951.1010 (rs_prerelease)), I lose my network connection. My laptop picks networks I have connected to before but after connection, it shows a "no connection" error. I tried uninstalling and reinstalling my wifi adapters, updating to latest versions then updating windows, but nothing works.
Could it be an incompatibility issue between the Windows 11 Insider Preview 10.0.25951.1010 (rs_prerelease) and my Intel® Wi-Fi 6 AX201 160MHz adapter?
If so, how do I fix this so I can keep my windows up to date?
Hello PrinceAb,
Thank you for posting on the Intel® communities. I understand you are having an issue with your wireless connection.
In this case, since you are using the Insider version of Windows 11 I recommend you to get in contact with Microsoft for drivers, and support, and to check for compatibility.
This is because Microsoft intended this version to work only with their exclusive updates and may be compatible with different components than the regular Windows 11 version.
Thanks for your understanding.
Please keep in mind that this thread will no longer be monitored by Intel.
Deivid A.
