Getting very low wifi speed in one laptop only - around 1Mbps (good in other laptop and mobile - around ~40Mbps). I have dell laptop with intel centrino advanced N6230 wireless adapter. I suspect some issue with wifi adapter advance properties messup. Any kind of help will be appreciated.Thanks in advance.
Hello Vikram6211,
As we understand, your system is showing connectivity issues. Based on your initial reply, we recommend you to apply the configuration from the following advisory:
http://www.intel.com/content/www/us/en/support/network-and-i-o/wireless-networking/000005544.html Recommended Settings for 802.11n Connectivity
If the issue persists, please provide more information:
- Was this working fine before?
- Does the issue happen with other wireless networks as well?
- https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility Download Intel® System Support Utility, run the tool in Windows* with the adapter working fine, and use it to create a report with all sections, once the report is created, click on the "Next" button. In the following screen, save the report to a file. Then use the Advanced editor options to add the resulting XML file to your post as an attachment.
Jonathan B.
Hello Vikram6211,
We haven't received any reply to our last comment. Feel free to contact us if you require further assistance.
Jonathan B.
