Hello i want to install a WiFI M.2 Module in to my Asus MAXIMe IX Hero MB.
for an i7-7gen CPU. What Wifi caqrds are compatible ?
So, first of all, you need to make a decision regarding what level of WiFi support you want. The best available is support for WiFi 6E (and Wireless-AX). You can also look at WiFi 6 (which is also Wireless-AX) or step down to WiFi 5 (and Wireless-AC). Frankly, the prices of these cards is so close together that I would say go for the best, even if you cannot initially use all of the abilities provided. The standard card Intel offers with WiFi 6E support is the AX210.
I scoured your motherboard's web page but could find no mention of any support for WiFi. What this means is that you will need to (also) purchase a PCIe x1 daughter card that provides this support.
All that said, here is an example of a complete package that provides the Intel AX210 WiFi 6E card, the PCIe daughter card and antennas: https://www.amazon.com/dp/B08NVR8M8X.
Note the following:
- The PCIe daughter cards require that they be installed in a PCIe x1 slot. You cannot install them in PCIe x4/x8/x16 slots. Your motherboard has two of these PCIe x1 slots; I hope that one of them is available
- In order to make use of the Bluetooth capability, the PCIe daughter cards come with a cable that you will need to connect to one of the motherboard's internal USB 2.0 connectors. You have only two of these connectors on your motherboard; I hope that one of them is available.
Hope this helps,
Hello Exodusol,
Steven G.
Since we have not heard back from you, we will close this thread. If you need any additional information, please submit a new question, as this thread will no longer be monitored.
Steven G.
