Wireless
Issues related to Intel® Wireless Adapters and technologies
6564 Discussions
Wifi Hotspot created not been shown (Centrino Advanced N-6205)
CJimé
Hello. I have created, via MS-DOS netsh commands, a wifi hotspot which is supposed to be started with no problem. But I can't see it from others devices, as an Android or iPhone phones or another laptop.
Searching the web I can not find any solution and would like to make sure about the Card Adapter.
I am using a Windows 7 64bits and an Intel Centrino Advanced N-6205 adapter.
I have created the virtual network by netsh commands and I have activated Internet Sharing Connectio of LAN over the virtual network. The network even seems to be connected to internet, but can not be found the ssid from other devices.
I have tried too using HP Connection Manager, which have an HP Mobile HotSpot Utility, with same results. It shows that the HotSpot is started, but no devices can find it.
The same when trying Connectify.
It is because of this that I am thiniking about a misconfiguration of the Card Adapter or any other thing I can not figure out.
Could anyone point me how to fix it.
Thank you!
ASouz7
Hello CarlosJim,
Please could you make sure if the SSID broadcast feature is enabled ?
Please let us know the details of the network settings such as, frequency (band) and channel used.
CJimé
Hello!
Thank you for your answer.
About making sure if the SSID broadcast feature is enabled, I actually don't know where to find it or how to configure it. :S
About the adapter:
Intel Centrino Advanced-N 6205
802.11n Bandwith for 2,4: Auto
802.11n Bandwith for 5,2: Auto
Preferred band: No preference
Ad Hoc Channel 802.11b/g: 11
802.11n Mode: On
Wireless mode: 802.11a/b/g
Ad Hoc QoS Mode: WMM Activated
This is the script I run. A difference can be seen about showing the info of the hostednetwork befor and after starting it.
C:\Users\jcjgomez>netsh wlan set hostednetwork mode=allow ssid=MySSID key=password
El modo de red hospedada se estableció en permitir.
Se cambió correctamente el SSID de la red hospedada.
Se cambió correctamente la frase de contraseña de clave de usuario de la red hospedada.
C:\Users\jcjgomez>netsh wlan show hostednetwork
Configuración de red hospedada
Modo: permitido
Nombre de SSID : "MySSID"
Nº máximo de clientes : 5
Autenticación : WPA2-Personal
Cifrado : CCMP
Estado de la red hospedada
Estado : No iniciado
C:\Users\jcjgomez>netsh wlan start hostednetwork
Se inició la red hospedada.
El grupo o recurso no está en el estado correcto para realizar la operación solicitada.
Hope this information helps.
Thank you again for answering
ASouz7
Hello CarlosJim,
Based on your latest information please set up an Ad Hoc connection by doing the following:
1 - Open command prompt with admin privileges.
2 - Type this command line: netsh wlan set hostednetwork mode=allow ssid= key=
3 - Once hosted network is created, it needs to be started, so please run this command: netsh wlan start hostednetwork
A confirmation message should appear: " The hosted network started"
If the SSID is not detected, then open the properties of the wireless connection (go to Network and Sharing Center) and make sure (ICS) Internet Connection Setting is enabled. Make sure to select the Ad Hoc connection under Home Networking Connection.
Let us know if this information helped you resolve this issue.
CJimé
Hello aleki_intel.
Thank you for replying.
I have passed throguh all the steps you have written and nothing new. The network seems to be started correctly, but it can not be seen from other devices.
This is what I have run in cmd:
C:\Users\jcjgomez>netsh wlan set hostednetwork mode=allow ssid=testNetwork key=12345678
Se inició la red hospedada.<------------------------------- The hosted network started in Spanish <span __jive_emoticon_name="wink" __jive_macro_name="emoticon" class="jive_macro jive_emote" src="/7.0.3.0/images/emoticons/wink.png">
I am sure of selecting the right home network connection and ICS activated.
Really don't know what is happening. In other laptops I have had no problems following these kind of instructions.(Specifically I can prove using it in a Toshiba Tecra R840 with an Intel(R) Centrino(R) Advanced-N 6230)
Thank you again for you time.
CJimé
Well, I have tried uninstalling every adapter in Device Manager and turning the Windows firewalñ on and off back a couple of times.
Now I can see the virtual network on other devices.
By now, the discussion can be closed.
Thank you for your time, aleki_intel. If I have problems again, I will write here to let people know.
ASouz7
Hello CarlosJim,
Could please be so kind and check this link below and let us know if the information on it helped you, please.
http://www.intel.com/support/wireless/wlan/sb/CS-034116.htm http://www.intel.com/support/wireless/wlan/sb/CS-034116.htm
