Hi
When I start laptop and try to connect wifi and enter password wifi disables and enables automatically
So could not make wifi connection please help me.
My driver's are updated and I reset my laptop still same issue
Please don't tell me you are up to date; that tells me nothing. Tell me exactly what versions you have installed.
Please download and run the Intel System Support Utility for Windows and have it save the report to a file. Then, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
Here is the file uploaded..
I have updated drivers using Intel Driver support assistant
Please let me know if further info needed
You seem to have the latest Wireless package, but the Bluetooth package is older. These are supposed to be kept in sync with each other. I suggest that you do a clean install of these packages.
First of all, download - but do not install just yet - the latest Bluetooth and WiFi drivers for your adapter. Here are links to these drivers:
- https://downloadcenter.intel.com/download/29538/Intel-Wireless-Bluetooth-for-Windows-10?wapkw=Wireless-AC%209560
- https://downloadcenter.intel.com/download/29520/Windows-10-Wi-Fi-Drivers-for-Intel-Wireless-Adapters?wapkw=Wireless-AC%209560
Now follow this process:
- Disable Internet access. Unplug Ethernet cable and/or disable wireless. Keep disabled until told to re-enable.
- From Apps & Features app, uninstall any instances of the Intel PROSet/Wireless Software and Intel Wireless Bluetooth. When prompted, choose to "Discard Settings".
- Manually shutdown and reboot your computer.
- In Device Manager > Network Adapters, check for entry for Intel Dual Band Wireless-AC 9560. If none, go to Step 8.
- Right click on the entry for your Intel Dual Band Wireless-AC 9560 and uninstall it., choosing to "Delete the driver software for this device".
- Go to Step 4.
- (Optional but recommended) Clean out all temporary files using the Windows Clean Disk tool. I recommend that you checkmark all categories offered, even if no files currently (so it leaves it set up for next invocation).
- Install the Bluetooth driver package. Always Bluetooth first.
- Install the Wireless driver package.
- Enable Internet access.
- Test.
Hope this helps,
I followed every step you said
and installed both bluetooth(First) and wireless driver
After rebooting i couldn't see Wifi in network connections
I can see intel wireless AC 9560 in device manager with yellow exclamation mark.
- Tags:
- I d
I cant see wifi in the bottom right corner. as well as in network connections
able to see only Ethernet.
In Device Manager, when you click on the icon with the yellow bang (!), what is the description of the problem? Have you tried running the Wireless Troubleshooter?
I tried running trouble shooter
Here i sthe screenshot
I got to know i dont get solution here in this community
so i did some research and found solution myself
- Tags:
- Get
