Wireless
8789 Discussions
Wifi disconnects AX200
akroeger
Dear all,
bought a new P14s Thinkpad last week. It has the Intel WiFi 6 AX200 integrated. Everything worked fine - also the wifi. I came home a few days ago and suddenly there are issues with my home wifi.
My home wifi works stable with all my other devices.
Tried updating, uninstalling, reinstalling, older driver versions - nothing seems to help. Windows scan / lenovo hardware scan are no help. Already switched to a quiet channel, but the same issues still occur.
Already ran the intel SSU. Please see attached.
Grateful for any help.
BW
AK
AndrewG_Intel
Hello @akroeger
In order to check this further and assist you better, could you please provide the following information?
1- Do you remember if this issue happened after a new Windows update or Wireless/Bluetooth driver update?
2- How often does the disconnection occur? Also, does it reconnect automatically? How long does it take to reconnect?
3- Is there any error message when the issue happens? Do you see any error code or error message under Device Manager >> Network Adapters >> Intel® Wireless Adapter >> Properties?
4- Have you tried a different router or Access point for testing purposes? Maybe one that is AX compatible? Have you rebooted your access-point, router, modem? Please provide details.
5- Have you checked if this issue happens testing only the computer and the router? (no other wireless devices connected to the wireless network during this test).
6- Router / Access point brand, model, and firmware version:
7- How far are you from the router? Are there any objects/walls blocking a straight sight to the device or anything that may cause interference (e.g. wireless phones, microwaves, etc.)?
8- Is the issue happening with both Wireless bands? (2.4GHz and 5GHz?)
Andrew G.
AndrewG_Intel
Hello akroeger
We are checking this thread and we would like to know if you need further assistance. Please do not hesitate to contact us back if you have additional inquiries.
Andrew G.
AndrewG_Intel
Hello akroeger
We have not heard back from you so we will proceed to close this inquiry now. If you need any additional information, please submit a new question as this thread will no longer be monitored.
If the issue persisted, our last recommendation is to check this further with your computer manufacturer or with your place of purchase for further assistance considering this is a new system so they can provide further debugging and suggestions and even check if it is required a system replacement.
Lenovo* Technical Support*
Andrew G.
*Links to third-party sites and references to third-party trademarks are provided for convenience and illustrative purposes only. Unless explicitly stated, Intel® is not responsible for the contents of such links, and no third-party endorsement of Intel® or any of its products is implied.
AndrewRK
Dear Intel Community,
I have the same problem. Working from home, my Lenovo P14s works fine with my hotspot but only intermittently disconnects from my router/nodes (Asus RT-AX88u and 2 x RT-AX58u, all wifi 6). I have checked that the routers and driver are up to date, tried sitting close to the routers.
Thanks for your help.
Andrew
