Wireless
7109 Discussions
Windows 10 Upgrade Wlan geht nicht mehr
CNosa
Hallo, Ich habe mein Laptop von Win 7 auf Win 10 upgraded. habe den 3945 ABG Network Connection Treiber. Werde im Internet nicht ganz so schlau draus, ob es ihn nun für Windows 10 gibt oder nicht. Bei dem Laptop geht das WLAN nicht mehr. Was kann ich nun tun? Habe den Intel PRO/WIRELESS 3945 ABG. Habe selbst gelesen, dass Windows 10 angeblich nicht mehr unterstützt wird, dann doch einen Treiber gefunden und installiert. Es tut sich trotzdem nichts. Was gibt es nun für Möglichkeiten?
AlHill
Sorry, your adapter is not supported on Windows 10:
http://www.intel.com/content/www/us/en/support/network-and-i-o/wireless-networking/000005602.html Supported Operating Systems for Intel® Wireless Products
Doc
CNosa
Ok thank you so much. Any idea what i can do know, ecxept grading down?
AlHill
You may want to contact the laptop manufacturer to see if there is an adaptor that is supported.
Or, maybe consider getting a new/newer laptop.
Doc
CNosa
All right. Thanks. I will try to contact the laptop manufacturer, cause I don't need a newer on. I still can use it bei ethernet connection.
Hello Carice,
Like Doc mentioned, this adapter is not compatible with Windows® 10. The last driver it received was actually for Windows* 7.
As far as alernatives go, you do have a couple. The simplest being to purchase an USB Wireless Adapter, which are relatively cheap and simple to install (plug and play, usually).
Aside from that, you would need to contact the manufacturer of your computer to see if there's a newer adapter that may be installed in place of your http://www.intel.com/content/www/us/en/support/network-and-i-o/wireless-networking/legacy-intel-wireless-products/intel-pro-wireless-products/intel-pro-wireless-3945abg-network-connection.html Intel® PRO/Wireless 3945ABG, or downgrade back to Windows* 7.
- https://support.microsoft.com/en-us/instantanswers/1235b5b0-bf94-4b77-9cbd-1c1a8337070c/going-back-to-windows-7-or-windows-8.1 Going back to Windows* 7
Note: Any links provided for third party tools or sites are offered for your convenience and should not be viewed as an endorsement by Intel® of the content, products, or services offered there. We do not offer support for any third party tool mentioned here.
We do hope this information helps. If you need any further assistance, just let us know.
Carlos A.
