Wireless
7932 Discussions
Windows DPC_WATCHDOG_VIOLATION Bluescreen
Harrycd
I've been having this issue where my computer will bluescreen after downloading or using a application. I have done a lot trying to fix it any help?
5007 - TX/CMD timeout (TfdQueue hanged)
Intel(R) Wi-Fi 6 AX200 160MHz : Has encountered an internal error and has failed.
5055 - HW error
Intel(R) Wi-Fi 6 AX200 160MHz : The network adapter has returned an invalid value to the driver.
5032 - Driver Miniport reset watchdog
Intel(R) Wi-Fi 6 AX200 160MHz : Has determined that the network adapter is not functioning properly.
5035 - Driver OSC Pending OID watchdog
Miniport Intel(R) Wi-Fi 6 AX200 160MHz, {2d3546b5-48d4-4653-8d05-65b2e119e2be}, had event Fatal error: The miniport has detected an internal error
DeividA_Intel
Hello Harrycd,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your Intel® Wi-Fi 6 AX200.
1. Is this the original adapter that came pre-installed on your computer or did you change/install the adapter to this one?
2. Is the Bluetooth working?
3. Is this a laptop or desktop computer?
4. What is the brand and model name of your laptop or motherboard (if desktop)?
5. What is the operating system installed, as well as the version and build?
6. What is the BIOS version installed?
Deivid A.
Andres_Intel
Hello Harrycd,
Andres P.
DeividA_Intel
Hello Harrycd,
I was checking your thread and see that we have not heard back from you.
I’m going to close your post, but if you need further assistance, please do not hesitate to create a new thread.
Deivid A.
jacum
hello i need assistance, i am suffering from the exact same problem and have been since i think august 2022.
