Bonjour, Je possède depuis peux un casque de réalité virtuelle (oculus quest 2) totalement autonome (batterie intégré, possibilité de jouer directement sur le casque sans PC requis).
Grace à un application du store oculus Virtual Desktop, je peux connecté mon casque VR sur mon ordinateur et profiter de la puissance de mon ordinateur.
Mon problème étant que la connexion en mode hotspot 5ghz sur Windows 10 ne dépasse pas les 286mbps sous la norme 802.11ax qui devrait atteindre les 2400mbps.
Je possède une carte Wifi Intel AX200 que j'ai acheté spécialement pour mon casque VR.
Merci d'avance pour vos réponses
Hello Antonin,
According to the link you provided, the wireless card you are using is not an Intel* Product, in this case, Ubit* uses the Intel* chipset with 3rd party components, so Intel* cannot confirm how the wireless card will work, or the specific drivers you will need.
As you can see on the link you shared, they have their own drivers, specifications, instructions, and FAQ.
Please, contact the Original Equipment Manufacturer so they will be able to assist you and guide you with the behavior you are experiencing.
Maria R.
Hello Antonin,
Thank you for posting on the Intel Community.
Our support is only provided in English. We may not be able to translate screenshots attached to the thread. To better assist you, we use a translation tool, hence; the translation may not be completely accurate.
Please provide us with the below information:
- Is the wireless card an integration you made to your system?
- Which tool are you using to check the speed?
Provide the Intel® System Support Utility (Intel® SSU)
- Download the Intel SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
- Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
Maria R.
Bonjour,
J'ai acheté une carte wifi 6 intel AX200 que j'ai ajouté à mon ordinateur de bureau sur le port PCIE.
Pour connaitre la vitesse de transmission je regarde dans le champs vitesse de transmission lors de la connexion au réseau Hotspot windows10 de mon ordinateur sur mon casque oculus.
Hello Antonin,
Thank you for the information.
Can you please provide us with pictures of the wireless card and pictures to see the connection of the wireless card in the motherboard, also, we will need to see the antennas and the PCIe connection.
Maria R.
Bonjour,
Voici la carte que j'ai acheter
J'ai trouver la source du problème il s'agit de la fréquences de la bande passante :
J'ai remarquer que dans les paramètre de la carte wifi il est configurer a seulement 20mhz avec 2 antennes donc j'obtient mes 287mps
Maintenant j'aimerais savoir comment paramètrer ma carte wifi en 160mhz ?
Thank you/Merci Antonin. I adjusted the frequence to 20MHz in my Intel 802.11 200AX and my Internet speed increased from 3Mbps to 8Mbps. My connection is of 100Mbps though.
Hello Antonin,
Maria R.
