Dell laptop running Windows 10 with Intel Dual Band wireless-AC 3165. I can connect to home secured wifi and successfully connected to other secured wifi spots. I can't connect to unsecured public wifi spots. Just tells me Not Connected when I 'Connect.' I tried disabling the wireless-AC 3165 device and re-enabling it. I also checked driver version and I am running latest version. Seem to have some success connecting to a secured wifi and then immediately trying to connect to an unsecured site. Need to be able to connect first time to unsecured sites.
Hello NashvilleTom,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your Intel® Dual Band Wireless-AC 3165.
1. Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
- Download the Intel® SSU and save the application on your computer: https://www.intel.com/content/www/us/en/download/18377/intel-system-support-utility-for-windows.html
- Open the application, check the "Everything" checkbox, and click "Scan" to see the system and device information. The Intel® SSU defaults to the "Summary View" on the output screen following the scan. Click the menu where it says "Summary" to change to "Detailed View".
- To save your scan, click Next and click Save.
2. Is this the original adapter that came pre-installed on your computer or did you change/install the adapter to this one?
3. Do you get any error or message when you try to connect to an unsecured Wi-Fi?
4. Do you see any errors or yellow marks at the device manager under your wireless adapter?
5. Were you able to connect to an unsecured Wi-Fi before? If so, when did the issue start?
Deivid A.
Thanks DeividA. Prior to receiving your request for more information, I uninstalled the device and re-installed it. Works as originally installed. I don't know what caused the situation. But, appreciate the response. I consider this closed.
Hello NashvilleTom,
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Deivid A.
Hello NashvilleTom,
I am glad to know that know your computer is working as originally. I will proceed to close this thread, however, bear in mind that you can open a new thread in case you need further support.
Deivid A.
