Wireless
8617 Discussions
Wireless-AC 7265 BSOD Error
Hello all,
I've had some issues with my wireless AC 7265 adapter. I noticed it was intermittently losing connection or losing major speed. I made the changes recommended here:
and so far I haven't that issue occur again.
However, earlier today I had a BSoD (blue screen of death) error (Driver_IRQL_not_less_or_equal netwtw02.sys) that forced my laptop to shut down and lose my work. I am wondering if there is a fix in the works or if anyone else has had this issue. I have the most current driver installed (18.30.0.9).
For more information on this, see here: http://answers.microsoft.com/en-us/windows/forum/windows_10-performance/driverirqlnotlessorequal-netwtw02sys/8947ed87-1213-41ef-b46b-e61b6373f509 http://answers.microsoft.com/en-us/windows/forum/windows_10-performance/driverirqlnotlessorequal-netwtw02sys/8947ed87-1213-41ef-b46b-e61b6373f509
This is a brand new laptop and it has had a lot of driver issues so it has been a little frustrating.
ASouz7
AlexROG,
Thank you for the information, we are working on the drivers in order to improve its performance. We will publish a new version when they become available. In the mean time, we recommend that you use the drivers provided by your OEM. After using the OEM's driver you notice that the issue still persists, you can use our generic drivers version: 18.21.x found in our download center: https://downloadcenter.intel.com/download/25514/Intel-PROSet-Wireless-Software-for-Windows-10 Intel® PROSet/Wireless Software for Windows® 10 - File Name: Wriless_18.21.0_t64.exe. We are going to create a service ticket for you so you can send us the log files and Windows* event logs.
Another option as well, would be to clean uninstall all the current drivers installed and use Windows* Update to install the drivers.
Please check you provite messages in order to create a service ticket for you.
kSand7
Hi there, have had similar problem with blue screens, about 3 a day leading to real system instability problems. I have installed the latest drivers dated 03/05/2016 because I assumed that as these were new drivers that this problem would have been sorted out. Within the last 8 hours I have had two blue screens of death relating to the wifi adapter.
I cannot even download much of anything as the wifi adapter keeps disconnecting and reconnecting.
Help please.
Kenny
ASouz7
footoomsh,
Could please confirm which OS you are using?
best regards,
Aleki
kSand7
ASouz7
footoomsh,
Intel has recently released a new driver version for this adapter for https://downloadcenter.intel.com/download/26214/Intel-PROSet-Wireless-Software-and-Drivers-for-Windows-10?product=83635 Windows®10. Please access this link: Intel® PROSet/Wireless Software and Drivers for Windows® 10 - Packet Version 19.2.0 in order to obtain access to it. The driver version in this package is the 18.33.3.2 . In some cases, a clean installation is needed. Here is how you can do it:
1. Download and save the drivers from the link above.
2. Go to Control Panel, Programs and Features and Uninstall "Intel® PROSet/Wireless Software", if it is installed. When prompted, choose the option to "Discard settings".
3. In Control Panel, Device Manager, Network Adapters, right click on the Intel® Dual Band Wireless-AC 7265 and Uninstall it. Make sure you mark the option to "Delete the driver software for this device".
4. Reboot the PC or scan for hardware changes, check device manager and if an older driver is detected and installed, repeat the actions to uninstall and delete it as well. Repeat this process until the OS does not allow deleting the driver, or until the controller shows as Unknown Device.
5. Install the Intel® Wireless driver. During the first steps of PROSet/Wireless installation, make sure to customize the installation and install all the 3 driver components.
Let us know if this helped you resolve this situation.
Aleki
Benjamin_S_Intel
I was seeing this same BSOD (DRIVER_IRQL_NOT_LESS_OR_EQUAL in netwtw02.sys) on my wireless AC 7265 adapter. I have a Lenovo Yoga 12 so I went to the Lenovo page and downloaded the wireless driver.
Driver Date: 9/24/2015
Driver Version: 18.21.0.2
With this driver installed I haven't seen the BSOD in a couple of days, hopefully it will continue this way.
I installed the same driver version. It was working fine for a couple days but today it started with BSOD error again.
Benjamin_S_Intel
I just saw they posted a new driver two days ago. https://downloadcenter.intel.com/download/25683/Intel-PROSet-Wireless-Software-for-Windows-10 Download Intel® PROSet/Wireless Software for Windows® 10
I installed it and hopefully it will fix the issue. We'll see after a few days of use.
Driver Version: 18.32.0.5
Driver Date: 12/22/2015
I am still getting BSOD errors regardless of the driver, even 18.32.0.5 still causes it.
I'm starting to wonder if intel can fix this. All the drivers cause the problem. Does this mean it is a hardware defect? Should I return my laptop?
Benjamin_S_Intel
It almost certainly a software defect. This bugcheck 0xD1 is caused by the kernel mode driver, netwtw02.sys. It's something Intel should be able to fix once they have a repro of the issue.
This explains more about the error: https://msdn.microsoft.com/en-us/library/windows/hardware/ff560244(v=vs.85).aspx https://msdn.microsoft.com/en-us/library/windows/hardware/ff560244(v=vs.85).aspx
Benjamin_S_Intel
I opened up the C:\Windows\MEMORY.dmp file that is generated when the BSOD happens and it is showing a slightly different bugcheck. This is only the latest bugcheck, I know the predominant one's I have seen were the bugcheck 0xD1.
Here is the Windbg analysis... it is an access violation (0xC0000005) in the netwtw02.sys which causes the SYSTEM_THREAD_EXCEPTION_NOT_HANDLED bugcheck. I don't have the symbols for the .sys file so we can't tell exactly what lead up to this crash, but hopefully an Intel person will reach out and I can share the .dmp file so they can analyze and fix.
2: kd> !analyze -v
* Bugcheck Analysis *
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED (7e)
This is a very common bugcheck. Usually the exception address pinpoints
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff8001498ec98, The address that the exception occurred at
Arg3: ffffd00048fb9c28, Exception Record Address
Arg4: ffffd00048fb9440, Context Record Address
Debugging Details:
*** ERROR: Module load completed but symbols could not be loaded for Netwtw02.sys
SYSTEM_SKU: LENOVO_MT_20DK_BU_Think_FM_ThinkPad S1 Yoga 12
SYSTEM_VERSION: ThinkPad S1 Yoga 12
BIOS_DATE: 07/24/2015
BASEBOARD_PRODUCT: 20DKS09J00
BASEBOARD_VERSION: SDK0E50510 WIN
BUGCHECK_P1: ffffffffc0000005
BUGCHECK_P2: fffff8001498ec98
BUGCHECK_P3: ffffd00048fb9c28
BUGCHECK_P4: ffffd00048fb9440
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%p referenced memory at 0x%p. The memory could not be %s.
FAULTING_IP:
Netwtw02+1ec98
fffff800`1498ec98 66418900 mov word ptr [r8],ax
EXCEPTION_RECORD: ffffd00048fb9c28 -- (.exr 0xffffd00048fb9c28)
ExceptionAddress: fffff8001498ec98 (Netwtw02+0x000000000001ec98)
ExceptionCode: c0000005 (Access violation)
ExceptionFlags: 00000000
NumberParameters: 2
Parameter[0]: 0000000000000001
Parameter[1]: 0000000000000000
Attempt to write to address 0000000000000000
CONTEXT: ffffd00048fb9440 -- (.cxr 0xffffd00048fb9440)
rax=0000000000000000 rbx=0000000000000001 rcx=ffffe000bc8f8b70
rdx=ffffd00048fb9f00 rsi=0000000000000000 rdi=ffffd00048fba000
rip=fffff8001498ec98 rsp=ffffd00048fb9e68 rbp=ffffd00048fb9f70
r8=0000000000000000 r9=000000000000002f r10=fffff80294c693c0
r11=fffff80294415001 r12=fffff80014ccc000 r13=ffffd00048fba040
r14=ffffe000bc6797e4 r15=0000000000000000
iopl=0 nv up ei ng nz na po nc
cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00010286
Netwtw02+0x1ec98:
fffff800`1498ec98 66418900 mov word ptr [r8],ax ds:002b:00000000`00000000=????
Resetting default scope
CPU_COUNT: 4
CPU_MHZ: 8f7
CPU_VENDOR: GenuineIntel
CPU_FAMILY: 6
CPU_MODEL: 3d
CPU_STEPPING: 4
DEFAULT_BUCKET_ID: NULL_DEREFERENCE
PROCESS_NAME: System
CURRENT_IRQL: 0
ERROR_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%p referenced memory at 0x%p. The memory could not be %s.
EXCEPTION_PARAMETER1: 0000000000000001
EXCEPTION_PARAMETER2: 0000000000000000
WRITE_ADDRESS: 0000000000000000
FOLLOWUP_IP:
Netwtw02+1ec98
BUGCHECK_STR: AV
ANALYSIS_VERSION: 10.0.10240.9 amd64fre
LAST_CONTROL_TRANSFER: from fffff80014972f20 to fffff8001498ec98
STACK_TEXT:
ffffd000`48fb9e68 fffff800`14972f20 : 00000000`00000000 ffffd000`48fb9f70 00000000`00000000 ffffd000`48fb9ff0 : Netwtw02+0x1ec98
ffffd000`48fb9e70 fffff800`14aee45d : 00000000`001c0001 fffff800`149737e7 ffffe000`bc90aa40 00000000`00000000 : Netwtw02+0x2f20
ffffd000`48fb9fc0 fffff800`149fdf57 : ffffe000`bc679174 00000000`00000025 00000000`00000000 fffff800`149f9195 : Netwtw02+0x17e45d
ffffd000`48fb9ff0 fffff800`14a37be6 : ffffd000`48fba180 fffff800`149f7ff5 00000000`00000000 00000000`00000000 : Netwtw02+0x8df57
ffffd000`48fba020 fffff800`14b05f51 : 00000000`00000000 ffffe000`bcac74e0 ffffe000`bc5b1470 ffffe000`bdb9cba0 : Netwtw02+0xc7be6
ffffd000`48fba160 fffff800`14b006b4 : ffffd000`48fba3a0 ffffe000`bc8f8b70 ffffd000`48fba3a0 ffff035d`53ed399d : Netwtw02+0x195f51
ffffd000`48fba250 fffff800`14b046f7 : fffff800`14c732d8 00000000`00000000 ffffd000`48fba3a0 00000000`00000020 : Netwtw02+0x1906b4
ffffd000`48fba280 fffff800`14b09925 : ffffe000`bc8f8b70 ffffe000`bf338f00 fffff800`00000006 ffffe000`bc5a7510 : Netwtw02+0x1946f7
ffffd000`48fba310 fffff800`14b07d85 : ffffe000`bc597e08 ffffe000`bf338f00 00000000`00000010 00000000`00000010 : Netwtw02+0x199925
ffffd000`48fba480 fffff800`14a5f41d : 00000000`00000001 ffffe000`bdb92fa0 00000000`00000030 ffffe000`bf338f00 : Netwtw02+0x197d85
ffffd000`48fba520 fffff800`1497ef8e : ffffe000`00000001 ffffe000`bc6797dc fffff800`14c32838 00000000`00000000 : Netwtw02+0xef41d
ffffd000`48fba590 fffff800`14a22b06 : ffffe000`bf338f00 00000000`00002605 ffffd000`48fba6f0 fffff800`14c39780 : Netwtw02+0xef8e
ffffd000`48fba5f0 fffff800`14991ec7 : ffffe000`bc6790f0 ffffe000`bc65da00 ffffd000`48fba810 fffff800`11941c7f : Netwtw02+0xb2b06
ffffd000`48fba780 fffff800`126f1b3f : 00000000`00000001 ffffe000`bc7971a0 00000000`e440001d fffff802`944576eb : Netwtw02+0x21ec7
ffffd000`48fba850 fffff800`1268f6e5 : ffffe000`bc7971a0 fffff800`150a9aa0 ffffe000`bc6ba080 ffffe000`bfb0b560 : ndis!ndisMRawInvokeOidRequest+0x9b
ffffd000`48fba890 fffff800`15028358 : 00000000`000000f8 fffff800`150a9aa0 ffffe000`bc6ba080 fffff800`150a9f90 : ndis!ndisMpHookInvokeOidRequestHandler+0x15
ffffd000`48fba8c0 fffff800`15035706 : 00000000`00000000 ffffe000`b978eb78 ffffe000`bc6ba460 fffff800`150a9fb0 : wdiwifi!CCtlPlane::SendWdiCommand+0x2b8
ffffd000`48fba940 fffff800`15035575 : 00000000`0000001d ffffe000`0000006d ffffe000`bfb0b560 fffff802`9445b84d : wdiwifi!DeviceCommandScheduler::OnIssueNext...
Benjamin_S_Intel
So far no BSOD seen. That's about a week since upgrading to 18.32.0.5 driver version.
TLi19
I am using AC 3165 but have the same DRIVER_IRQL_NOT_LESS_THAN_EQUAL BSOD. 18.32.0 is significant more stable than the 18.21.0 version but BSOD still happens. The only version I know that is stable is 18.12.0.
ASouz7
Thomas5267,
What is your system information?
Is this Wireless adapter the one that came installed by factory ?
ASouz7
AlexROG,
Please try driver version 18.32.0 foound in this link: https://downloadcenter.intel.com/download/25683/Intel-PROSet-Wireless-Software-for-Windows-10 Download Intel® PROSet/Wireless Software for Windows® 10 File name: Wireless_18.32.0_PROSet64_Win10.exe
TLi19
It is a brand new MSI GE62 6QC Apache I bought a month ago. The wireless adapter is installed by factory and not an add-on afterwards.
The specs are as follows:
Windows 10 Home
i7 6700HQ
2x 2133 Hz 8 GB DDR4 by Hyundai Electronics
GTX960M graphics card
Killer E2400 NIC
Intel 3165 Wireless card
128 GB Toshiba SSD
1 TB HGST HDD
I am pretty sure this is not a hardware failure of RAM or CPU. I did 10 hours of Prime 95 Small FFT, 24 hours of memtest86, 10 hours of memtest86+, and 10 iterations of the IntelBurnTest on the maximum setting when I bought this computer just to make sure it is stable. No error were returned by these tests.
I am pretty sure this is a driver issue. I had no problems with 18.12.0 but a huge amount of BSOD with 18.21.0. I have some BSOD with 18.32.0 but it is miles ahead of 18.21.0. Every time I change drivers I first uninstall the Intel software from Programs and Features and then uninstall the drivers in Device Manager. I then reboot and install the different version of driver and reboot again before using it.
I have noticed a few peculiarities with the BSODs:
  1. I never had BSOD when I was back home using my home wireless network. I am not sure whether I was using 18.12.0 or 18.21.0 at that time. 18.12.0 was always stable for me even in my dorm room where 18.21.0 would BSOD like crazy.
  2. When I was using 18.21.0, almost every time when there is a change in wireless signal strength (as indicated by the wireless icon on the taskbar) there will be a bluescreen (DRIVER_IRQL_NOT_LESS_THAN_EQUAL). The network strength first dip down, then after a few seconds later it goes back up. If a BSOD is going to happen, it will happen within 5 seconds of the signal strength going back up. My guess is that this has something to do with AP roaming. At home, I was using a single access point setup and there is no AP that I can access nearby. However, in my dorm building there are multiple AP with the same SSID. I suspect the BSODs are partly triggered by roaming between AP with same SSID. For your information, the home network is encrypted using the normal WPA2 and the dorm wireless network is encrypted using WPA2 Enterprise with CCMP.
  3. In the System section of Event Viewer in Windows, there are events from Netwtw02 with event ID 7001 and 7002. The event description for event ID 7001 is:
    "The description for Event ID 7001 from source Netwtw02 cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
    If the event originated on another computer, the display information had to be saved with the event.
    The following information was included with the event:
    \Device\NDMP3
    Intel(R) Dual Band Wireless-AC 3165
    The specified resource type cannot be found in the image file"
    It is the same for event ID 7002 with 7001 replaced with 7002. I do not know whether this is related to the BSODs.
Hope this helps.
ASouz7
thomas5267,
Thank you for the information. We are going to investigate it an will get back to you as soon as possible.
SCorn2
I got a BSOD in Windows 10 with the 18.32.0.5 driver on the Wireless-AC 7260 card.
My Dell laptop is about a year old and it's the first time I've ever had a BSOD in either Windows 8.1 or Windows 10.
I believe this version of the driver was delivered via a Windows update, although I normally update the Intel drivers myself.
Simon
Background information:
Intel(R) Dual Band Wireless-AC 7260
System Model: Dell XPS13 9333
This is the output from Windbg:
Microsoft (R) Windows Debugger Version 6.3.9600.17200 X86
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\013116-6890-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
************* Symbol Path validation summary **************
Response Time (ms) Location
Deferred srv*C:\symbols*http://msdl.microsoft.com/downloads/symbols http://msdl.microsoft.com/downloads/symbols
Symbol search path is: srv*C:\symbols*http://msdl.microsoft.com/downloads/symbols http://msdl.microsoft.com/downloads/symbols
Executable search path is:
Windows 8 Kernel Version 10586 MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Built by: 10586.63.amd64fre.th2_release.160104-1513
Machine Name:
Kernel base = 0xfffff801`d128e000 PsLoadedModuleList = 0xfffff801`d156cc70
Debug session time: Sun Jan 31 11:03:14.268 2016 (UTC + 0:00)
System Uptime: 0 days 23:25:44.076
Loading Kernel Symbols
Press ctrl-c (cdb, kd, ntsd) or ctrl-break (windbg) to abort symbol loads that take too long.
Run !sym noisy before .reload to track down problems loading symbols.
Loading User Symbols
Loading unloaded module list
Use !analyze -v to get detailed debugging information.
BugCheck D1, {98, 2, 0, fffff8004c38ff64}
*** WARNING: Unable to verify timestamp for Netwbw02.sys
*** ERROR: Module load completed but symbols could not be loaded for Netwbw02.sys
Probably caused by : Netwbw02.sys ( Netwbw02+4ff64 )
Followup: MachineOwner
0: kd> !analyze -v
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: 0000000000000098, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, value 0 = read operation, 1 = write operation
Arg4: fffff8004c38ff64, address which referenced memory
Debugging Details:
READ_ADDRESS: unable to get nt!MmSpecialPoolStart
unable to get nt!MmSpecialPoolEnd
unable to get nt!MmPagedPoolEnd
unable to get nt!MmNonPagedPoolStart
unable to get nt!MmSizeOfNonPagedPoolInBytes
0000000000000098
CURRENT_IRQL: 2
FAULTING_IP:
Netwbw02+4ff64
fffff800`4c38ff64 8b8098000000 mov eax,dword ptr [rax+98h]
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT
BUGCHECK_STR: AV
ANALYSIS_VERSION: 6.3.9600.17237 (debuggers(dbg).140716-0327) x86fre
TRAP_FRAME: ffffd0002cd45500 -- (.trap 0xffffd0002cd45500)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=0000000000000000 rbx=0000000000000000 rcx=ffffe000ff77c900
rdx=ffffe00103524700 rsi=0000000000000000 rdi=0000000000000000
rip=fffff8004c38ff64 rsp=ffffd0002cd45698 rbp=ffffd0002cd45710
r8=ffffd0002cd45770 r9=0000000000000000 r10=0000000000000001
r11=ffffd0002cd45470 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
Netwbw02+0x4ff64:
fffff800`4c38ff64 8b8098000000 mov eax,dword ptr [rax+98h] ds:00000000`00000098=????????
LAST_CONTROL_TRANSFER: from fffff801d13db2e9 to fffff801d13d0770
STACK_TEXT:
ffffd000`2cd453b8 fffff801`d13db2e9 : 00000000`0000000a 00000000`00000098 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
ffffd000`2cd453c0 fffff801`d13d9ac7 : ffffe001`031ee398 00000000`00000000 ffffd000`2cd45770 ffffe001`03432a10 : nt!KiBugCheckDispatch+0x69
ffffd000`2cd45500 fffff800`4c38ff64 : fffff800`4c37d395 00000000`000001a7 fffff800`4c37da29 ffffe001`00000000 : nt!KiPageFault+0x247
ffffd000`2cd45698 fffff800`4c37d395 : 00000000`000001a7 fffff800`4c37da29 ffffe001`00000000 fffff800`4c4ff7f3 : Netwbw02+0x4ff64
ffffd000`2cd456a0 00000000`000001a7 : fffff800`4c37da29 ffffe001`00000000 fffff800`4c4ff7f3 00000000`00001a70 : Netwbw02+0x3d395
ffffd000`2cd456a8 fffff800`4c37da29 : ffffe001`00000000 fffff800`4c4ff7f3 00000000`00001a70 ffffd000`2cd45700 : 0x1a7
ffffd000`2cd456b0 ffffe001`00000000 : ff...
SCorn2
Another BSOD in Windows 10 with the 18.32.0.5 driver on the Wireless-AC 7260 card.
Microsoft (R) Windows Debugger Version 10.0.10586.567 AMD64
Loading Dump File [C:\Windows\Minidump\030116-6453-01.dmp]
Windows 10 Kernel Version 10586 MP (4 procs) Free x64
Built by: 10586.103.amd64fre.th2_release.160126-1819
Machine Name:
Kernel base = 0xfffff803`af21b000 PsLoadedModuleList = 0xfffff803`af4f9cf0
Debug session time: Tue Mar 1 09:20:20.390 2016 (UTC + 0:00)
System Uptime: 0 days 9:34:29.210
BugCheck 133, {1, 1e00, 0, 0}
Probably caused by : Netwbw02.sys ( Netwbw02+39676 )
0: kd> !analyze -v
DPC_WATCHDOG_VIOLATION (133)
The DPC watchdog detected a prolonged run time at an IRQL of DISPATCH_LEVEL
or above.
Arguments:
Arg1: 0000000000000001, The system cumulatively spent an extended period of time at
DISPATCH_LEVEL or above. The offending component can usually be
identified with a stack trace.
Arg2: 0000000000001e00, The watchdog period.
Arg4: 0000000000000000
Debugging Details:
DUMP_CLASS: 1
DUMP_QUALIFIER: 400
BUILD_VERSION_STRING: 10586.103.amd64fre.th2_release.160126-1819
SYSTEM_MANUFACTURER: Dell Inc.
SYSTEM_PRODUCT_NAME: XPS13 9333
SYSTEM_SKU: 060A
BIOS_VENDOR: Dell Inc.
BIOS_VERSION: A08
BIOS_DATE: 08/31/2015
BASEBOARD_MANUFACTURER: Dell Inc.
BASEBOARD_PRODUCT: 0D13CR
BASEBOARD_VERSION: A00
DUMP_TYPE: 2
BUGCHECK_P1: 1
BUGCHECK_P2: 1e00
BUGCHECK_P3: 0
BUGCHECK_P4: 0
DPC_TIMEOUT_TYPE: DPC_QUEUE_EXECUTION_TIMEOUT_EXCEEDED
CPU_COUNT: 4
CPU_MHZ: a22
CPU_FAMILY: 6
CPU_MODEL: 45
CPU_STEPPING: 1
CPU_MICROCODE: 6,45,1,0 (F,M,S,R) SIG: 1D'00000000 (cache) 1D'00000000 (init)
BUGCHECK_STR: 0x133
CURRENT_IRQL: d
ANALYSIS_SESSION_HOST: DELL-LAPTOP-01
ANALYSIS_SESSION_TIME: 03-01-2016 11:17:30.0801
ANALYSIS_VERSION: 10.0.10586.567 amd64fre
LAST_CONTROL_TRANSFER: from fffff803af376bbb to fffff803af35d480
STACK_TEXT:
fffff803`b1176d48 fffff803`af376bbb : 00000000`00000133 00000000`00000001 00000000`00001e00 00000000`00000000 : nt!KeBugCheckEx
fffff803`b1176d50 fffff803`af23a037 : fffff803`b1176e00 00000000`00000001 ffffe001`b6fbe010 fffff803`af538180 : nt! ?? ::FNODOBFM::`string'+0xadbb
fffff803`b1176de0 fffff803`af9e99c5 : 00000000`00400a02 fffff803`af538180 ffffe001`b596aaa0 00000000`0000a101 : nt!KeClockInterruptNotify+0xa7
fffff803`b1176f40 fffff803`af303ea7 : ffffe001`b7e39800 fffff803`af26f9ec fffff803`b1176f50 00000000`00000010 : hal!HalpTimerClockIpiRoutine+0x15
fffff803`b1176f70 fffff803`af35e8aa : fffff803`afa343b0 ffffe001`b596aaa0 fffff801`8af40000 ffffe001`b586ed00 : nt!KiCallInterruptServiceRoutine+0x87
fffff803`b1176fb0 fffff803`af35ecd7 : 00000000`3c3f61c6 00000000`3c396b2f ffffe001`b596aaa0 fffff801`8b129b46 : nt!KiInterruptSubDispatchNoLockNoEtw+0xea
ffffd000`22de13a0 fffff803`af23d107 : 00000000`00000000 fffff801`8af78e50 ffffe001`b5969aa0 00000000`00000000 : nt!KiInterruptDispatchNoLockNoEtw+0x37
ffffd000`22de1530 fffff803`af22f132 : 00000000`00000002 ffffffff`00000000 40030001`0...
JDeen
Just to add to the thread, this was the only google thread that turned up searching some terms of the memory dump.
I'm having SYSTEM_THREAD_EXCEPTION_NOT_HANDLED (7e)
With exactly the same wireless-AC 7265
Interestingly almost exactly the same laptop as Simon above here, Dell XPS 13 9343
Could this be a Dell thing?
Anyway, the driver was from November so I updated it to 18.32.05 (same as above), let's see what happens....
