Wireless
7431 Discussions
Wireless-AC 7265 BSOD Error
Hello all,
I've had some issues with my wireless AC 7265 adapter. I noticed it was intermittently losing connection or losing major speed. I made the changes recommended here:
and so far I haven't that issue occur again.
However, earlier today I had a BSoD (blue screen of death) error (Driver_IRQL_not_less_or_equal netwtw02.sys) that forced my laptop to shut down and lose my work. I am wondering if there is a fix in the works or if anyone else has had this issue. I have the most current driver installed (18.30.0.9).
For more information on this, see here: http://answers.microsoft.com/en-us/windows/forum/windows_10-performance/driverirqlnotlessorequal-netwtw02sys/8947ed87-1213-41ef-b46b-e61b6373f509 http://answers.microsoft.com/en-us/windows/forum/windows_10-performance/driverirqlnotlessorequal-netwtw02sys/8947ed87-1213-41ef-b46b-e61b6373f509
This is a brand new laptop and it has had a lot of driver issues so it has been a little frustrating.
Benjamin_S_Intel
I don't see any reason to suspect Dell. My repro was on a Lenovo system. The faulting module is an Intel driver, it is all but guaranteed to be a driver bug.
By teh way, I haven't had any BSOD's since I upgraded to 18.32.0.5.
ASouz7
  • zambamingi Jocham SimonCornforth
We have released version 18.33.0 on our download center. Please check it out. This new version contains a lot of fixes.
Here you can find the link to it: https://downloadcenter.intel.com/product/83635/Intel-Dual-Band-Wireless-AC-7265 Drivers & Software
SCorn2
18.33.0.1 seems to have done the trick for me (so far at least). I've had it installed for a few weeks and haven't had an Intel-related BSOD since then.
Intel(R) Dual Band Wireless-AC 7260
System Model: Dell XPS13 9333
Windows 10
ASouz7
SimonCornforth,
Thanks for letting us know that this version worked for you.
SCorn2
I upgraded from 18.33.0.1 to 18.33.0.2 (which is distributed as part of 15.40.18.4380 win64_154018.4380.exe) a few weeks ago and since then have been getting about one BSOD a week from 18.33.0.2
Card:Intel(R) Dual Band Wireless-AC 7260
OS:Windows 10
Microsoft (R) Windows Debugger Version 10.0.10586.567 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\013116-6890-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
************* Symbol Path validation summary **************
Response Time (ms) Location
Deferred srv*C:\symbols*http://msdl.microsoft.com/downloads/symbols http://msdl.microsoft.com/downloads/symbols
Symbol search path is: srv*C:\symbols*http://msdl.microsoft.com/downloads/symbols http://msdl.microsoft.com/downloads/symbols
Executable search path is:
Windows 10 Kernel Version 10586 MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Built by: 10586.63.amd64fre.th2_release.160104-1513
Machine Name:
Kernel base = 0xfffff801`d128e000 PsLoadedModuleList = 0xfffff801`d156cc70
Debug session time: Sun Jan 31 11:03:14.268 2016 (UTC + 0:00)
System Uptime: 0 days 23:25:44.076
Loading Kernel Symbols
Press ctrl-c (cdb, kd, ntsd) or ctrl-break (windbg) to abort symbol loads that take too long.
Run !sym noisy before .reload to track down problems loading symbols.
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck D1, {98, 2, 0, fffff8004c38ff64}
*** WARNING: Unable to verify timestamp for Netwbw02.sys
*** ERROR: Module load completed but symbols could not be loaded for Netwbw02.sys
Probably caused by : Netwbw02.sys ( Netwbw02+4ff64 )
Followup: MachineOwner
0: kd> !analyze -v
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: 0000000000000098, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, value 0 = read operation, 1 = write operation
Arg4: fffff8004c38ff64, address which referenced memory
Debugging Details:
DUMP_CLASS: 1
DUMP_QUALIFIER: 400
BUILD_VERSION_STRING: 10586.63.amd64fre.th2_release.160104-1513
SYSTEM_MANUFACTURER: Dell Inc.
SYSTEM_PRODUCT_NAME: XPS13 9333
SYSTEM_SKU: 060A
BIOS_VENDOR: Dell Inc.
BIOS_VERSION: A08
BIOS_DATE: 08/31/2015
BASEBOARD_MANUFACTURER: Dell Inc.
BASEBOARD_PRODUCT: 0D13CR
BASEBOARD_VERSION: A00
DUMP_TYPE: 2
BUGCHECK_P1: 98
BUGCHECK_P2: 2
BUGCHECK_P3: 0
BUGCHECK_P4: fffff8004c38ff64
READ_ADDRESS: fffff801d160c520: Unable to get MiVisibleState
0000000000000098
CURRENT_IRQL: 2
FAULTING_IP:
Netwbw02+4ff64
fffff800`4c38ff64 8b8098000000 mov eax,dword ptr [rax+98h]
CPU_COUNT: 4
CPU_MHZ: a22
CPU_VENDOR: GenuineIntel
CPU_FAMILY: 6
CPU_MODEL: 45
CPU_STEPPING: 1
CPU_MICROCODE: 6,45,1,0 (F,M,S,R) SIG: 1D'00000000 (cache) 1D'00000000 (init)
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT
BUGCHECK_STR: AV
PROCESS_NAME: System
ANALYSIS_SESSION_HOST: DELL-LAPTOP-01
ANALYSIS_SESSION_TIME: 02-05-2016 19:41:10.0457
ANALYSIS_VERSION: 10.0.10586.567 amd64fre
TRAP_FRAME: ffffd0002cd45500 -- (.trap 0xffffd0002cd45500)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=0000000000000000 rbx=0000000000000000 rcx=ffffe000ff77c900
rdx=ffffe00103524700 rsi=0000000000000000 rdi=0000000000000000
rip=fffff8004c38ff64 rsp=ffffd0002cd45698 rbp=ffffd0002cd45710
r8=ffffd0002cd45770 r9=0000000000000000 r10=0000000000000001
r11=ffffd0002cd45470 r12=0000000000000000 r13=0000000000000000
r14=000...
JDeen
I've been using the 18.33.01 drivers for a while now, however still the occasionally crash.
In fact it always happens when I wake the laptop from sleep!! (frequently when I change places...) Any thoughts?
Here is the latest memorydump:
KERNEL_SECURITY_CHECK_FAILURE (139)
A kernel component has corrupted a critical data structure. The corruption
could potentially allow a malicious user to gain control of this machine.
Arguments:
Arg1: 0000000000000002, Stack cookie instrumentation code detected a stack-based
buffer overrun.
Arg2: ffffd0004e91ae20, Address of the trap frame for the exception that caused the bugcheck
Arg3: ffffd0004e91ad78, Address of the exception record for the exception that caused the bugcheck
Arg4: 0000000000000000, Reserved
Debugging Details:
Page 340 not present in the dump file. Type ".hh dbgerr004" for details
DUMP_CLASS: 1
DUMP_QUALIFIER: 401
BUILD_VERSION_STRING: 10586.212.amd64fre.th2_release_sec.160328-1908
SYSTEM_PRODUCT_NAME: XPS 13 9343
SYSTEM_SKU: 0665
BIOS_VERSION: A07
BIOS_DATE: 11/11/2015
BASEBOARD_PRODUCT: 0F5KF3
DUMP_TYPE: 1
BUGCHECK_P1: 2
BUGCHECK_P2: ffffd0004e91ae20
BUGCHECK_P3: ffffd0004e91ad78
BUGCHECK_P4: 0
TRAP_FRAME: ffffd0004e91ae20 -- (.trap 0xffffd0004e91ae20)
rax=fffff80133c77850 rbx=0000000000000000 rcx=0000000000000002
rdx=ffffe000197cf010 rsi=0000000000000000 rdi=0000000000000000
rip=fffff801339c4875 rsp=ffffd0004e91afb8 rbp=ffffe00019324010
r8=ffffe000197cf010 r9=0000000fffffffff r10=fffffd8000002190
r11=ffffd0004e91af30 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei ng nz ac po nc
Netwtw02+0x24875:
fffff801`339c4875 cd29 int 29h
Resetting default scope
EXCEPTION_RECORD: ffffd0004e91ad78 -- (.exr 0xffffd0004e91ad78)
ExceptionAddress: fffff801339c4875 (Netwtw02+0x0000000000024875)
ExceptionCode: c0000409 (Security check failure or stack buffer overrun)
ExceptionFlags: 00000001
NumberParameters: 1
Parameter[0]: 0000000000000002
Subcode: 0x2 FAST_FAIL_STACK_COOKIE_CHECK_FAILURE
CPU_COUNT: 4
CPU_MHZ: a22
CPU_FAMILY: 6
CPU_MODEL: 3d
CPU_STEPPING: 4
CPU_MICROCODE: 6,3d,4,0 (F,M,S,R) SIG: 1F'00000000 (cache) 1F'00000000 (init)
BUGCHECK_STR: 0x139
CURRENT_IRQL: 2
ERROR_CODE: (NTSTATUS) 0xc0000409 - The system detected an overrun of a stack-based buffer in this application. This overrun could potentially allow a malicious user to gain control of this application.
EXCEPTION_CODE: (NTSTATUS) 0xc0000409 - The system detected an overrun of a stack-based buffer in this application. This overrun could potentially allow a malicious user to gain control of this application.
EXCEPTION_CODE_STR: c0000409
EXCEPTION_PARAMETER1: 0000000000000002
DEFAULT_BUCKET_ID: STACK_COOKIE_CHECK_FAILURE
WATSON_BKT_EVENT: BEX
ANALYSIS_SESSION_HOST: JOCHEM-XPS13
ANALYSIS_SESSION_TIME: 04-23-2016 00:42:19.0388
ANALYSIS_VERSION: 10.0.10586.567 x86fre
LAST_CONTROL_TRANSFER: from fffff800083532e9 to fffff80008348760
FAULTING_THREAD: 0000000000000000
STACK_TEXT:
ffffd000`4e91aaf8 fffff800`083532e9 : 00000000`00000139 00000000`00000002 ffffd000`4e91ae20 ffffd000`4e91ad78 : nt!KeBugCheckEx
ffffd000`4e91ab00 fffff800`08353610 : ffffe000`17f9f040 00000000`00000001 ffffe000`1929f000 fffff801`33c65838 : nt!KiBugCheckDispatch+0x69
ffffd000`4e91ac40 fffff800`083527f3 : ffffe000`1929f00c ffffe000`1929f00c ffffe000`0f01c7e4 00000000`00000000 : nt!KiFastFailDispatch+0xd0
ffffd000`4e91ae20 fffff801`339c4875 : fffff801`33b43389 ffffe000`0f01c174 fffff801`33ca8098 ffffd000`4e91b0b0 : nt!KiRaiseSecurityCheckFailure+0xf3
ffffd000`4e91afb8 fffff801`33b43389 : ffffe000`0f01c174 fffff801`33ca8098 ffffd000`4e91b0b0 ffffe000`193246ea : Netwtw02+0x24875
ffffd000`4e91afc0 37324142`37424350 : 42435055`202d2046 ff004637`32414237 ffffe000`0e3cd288 fffff800`089d31ce : Netwtw02+0x1a3389
ffffd000`4e91b1f0 42435055`202d2046 : ff004637`32414237 ffffe000`0e3cd288 fffff800`089d31ce 00000000`00000000 : 0x37324142`37424350
ffffd000`4e91b1f8 ff004637`32414237 : ffffe000`0e3cd288 fffff800`089d31ce 00000000`00000000 fffff801`00000000 : 0x42435055`202d2046
ffffd000`4e91b200 ffffe000`0e3cd288 : fffff800`089d31ce 00000000`00000000 fffff801`00000000 fffff801`33c65838 : 0xff004637`32414237
ffffd000`4e91b208 fffff800`089d31ce : 00000000`00000000 fffff801`00000000 fffff801`33c65838 ffffe000`0f0a1b01 : 0xffffe000`0e3cd288
ffffd000`4e91b210 6c667065`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : hal!KeQueryPerformanceCounter+0x6e
ffffd000`4e91b240 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 ffff26ce`0c12efac : 0x6c667065`00000000
THREAD_SHA1_HASH_MOD_FUNC: bcf090c7d52dc5a526cc31286b2f204b81e6ffa0
THREAD_SHA1_HASH_MOD_FUNC_OFFSET: ad8ae251b4e751bee862f4ea...
ASouz7
Jocham,
Have you tried driver version 18.40.x as it contain many fixes that might hel you get rid of this situation. Inte recommends to use the computer manufacturer latest driver version first. You may find their contact information here: http://www.intel.com/content/www/us/en/support/topics/OEMs.html Computer Manufacturer Support Websites
Alternatively, you can use our generic drivers found in our donwload center. Here is the link to it: https://downloadcenter.intel.com/product/83635/Intel-Dual-Band-Wireless-AC-7265 Downloads for Intel® Dual Band Wireless-AC 7265 - Junt make to download the drivers according to your you OS version and architecture.
SCorn2
I reported on 17-04-2016 that I was getting about one Netwbw02.sys-related crash a week on 18.33.0.2 (which is distributed as part of 15.40.18.4380 win64_154018.4380.exe). Since that date I haven't had any Netwbw02.sys-related crashes.
OS:Windows 10
ASouz7
SimonCornforth,
Thanks for letting us know. Please keep us informed should you our assistance. We will be more than glad to assist you.
JL2
Hello I found this thread through a Google search and I've been having the same issues.
This is the fourth BSOD in a month. I was using a previous version of the driver but even after updating to the most recent version I'm still getting the same BSOD.
I'm currently using Windows 10 with Wireless-AC 7260 version 18.33.0.1.
Loading Dump File [C:\Windows\Minidump\030616-3875-01.dmp]
Built by: 10586.122.amd64fre.th2_release_inmarket.160222-1549
Machine Name:
Kernel base = 0xfffff802`efc79000 PsLoadedModuleList = 0xfffff802`eff57cf0
Debug session time: Sun Mar 6 15:25:19.604 2016 (UTC - 5:00)
System Uptime: 0 days 0:25:45.310
BugCheck A, {8, 2, 0, fffff802efc21675}
Probably caused by : Netwbw02.sys ( Netwbw02+926ad )
0: kd> !analyze -v
IRQL_NOT_LESS_OR_EQUAL (a)
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: 0000000000000008, memory referenced
Arg3: 0000000000000000, bitfield :
bit 0 : value 0 = read operation, 1 = write operation
bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
Arg4: fffff802efc21675, address which referenced memory
Debugging Details:
DUMP_CLASS: 1
DUMP_QUALIFIER: 400
BUILD_VERSION_STRING: 10586.122.amd64fre.th2_release_inmarket.160222-1549
SYSTEM_MANUFACTURER: ASUSTeK COMPUTER INC.
SYSTEM_PRODUCT_NAME: K501LX
SYSTEM_SKU: ASUS-NotebookSKU
SYSTEM_VERSION: 1.0
BIOS_VENDOR: American Megatrends Inc.
BIOS_VERSION: K501LX.206
BIOS_DATE: 09/16/2015
BASEBOARD_MANUFACTURER: ASUSTeK COMPUTER INC.
BASEBOARD_PRODUCT: K501LX
BASEBOARD_VERSION: 1.0
DUMP_TYPE: 2
BUGCHECK_P1: 8
BUGCHECK_P2: 2
BUGCHECK_P3: 0
BUGCHECK_P4: fffff802efc21675
READ_ADDRESS: fffff802efff7520: Unable to get MiVisibleState
0000000000000008
CURRENT_IRQL: 2
FAULTING_IP:
hal!HalPutScatterGatherList+18b35
fffff802`efc21675 4d8b6d08 mov r13,qword ptr [r13+8]
CPU_COUNT: 4
CPU_MHZ: 95a
CPU_FAMILY: 6
CPU_MODEL: 3d
CPU_STEPPING: 4
BUGCHECK_STR: AV
ANALYSIS_SESSION_HOST: ASUS24
ANALYSIS_SESSION_TIME: 03-06-2016 15:28:00.0315
TRAP_FRAME: fffff802f1b0c5a0 -- (.trap 0xfffff802f1b0c5a0)
rax=0000000000000001 rbx=0000000000000000 rcx=0000000000000001
rdx=0000000000000002 rsi=0000000000000000 rdi=0000000000000000
rip=fffff802efc21675 rsp=fffff802f1b0c730 rbp=000000000000001c
r8=ffffe000355a5990 r9=ffffe00037aa2336 r10=ffffe000355a5990
r11=ffffe00038f8cbd0 r12=0000000000000000 r13=0000000000000000
iopl=0 nv up ei pl nz na ...
ASouz7
JL624,
Is there an specific task you are trying to do that causes the BSOD or does it happen out of the blue?
JL2
Hi Aleki,
This happens randomly out of the blue. I'd be in the middle of watching a video on Youtube or just reading a post on Chrome.
ASouz7
JL624,
Is this wireless adapter the one the was installed by factory?
JL2
Yes, it is the factory installed wireless adapter.
Alek_S_Intel
JL624,
Please check your private messages.
RLazo
Dell Inspiron 13z touch
same trouble .... even with 18.40.0 driver
randomly collapsing .. i really cant work.
this is a dissaster
RLazo
version 18.21.0 is working fine until now - I think the issue /in my case at least/ is somehow connected to Connectify software or just creating a hot spot in general.
all the newer drivers are crushing.
SWang72
I have the exact same problem for 20 laptops in corporate environment. Can we get the driver working for version 18.4 for Wireless AC-7265 Win7 x64? The latest driver wont install on Win7
Here is my post in Lenovo page
https://forums.lenovo.com/t5/ThinkPad-X-Series-Laptops/Lenovo-X1-20BT-Carbon-Random-BSOD-Wireless-Driver-18-2-Unable-to/m-p/3311883/highlight/false# M69748 Lenovo X1 20BT Carbon - Random BSOD - Wireless Dri... - Lenovo Community
Benjamin_S_Intel
After a long time of not seeing any BSOD's with 18.32.0.5 driver, I just hit a bugcheck 0x133. I'll try latest driver from Intel.com, https://downloadcenter.intel.com/download/25833/Intel-PROSet-Wireless-Software-and-Drivers-for-Windows-10?product=83635 Download Intel® PROSet/Wireless Software and Drivers for Windows® 10.
0: kd> !analyze -v
DPC_WATCHDOG_VIOLATION (133)
The DPC watchdog detected a prolonged run time at an IRQL of DISPATCH_LEVEL
or above.
Arguments:
Arg1: 0000000000000000, A single DPC or ISR exceeded its time allotment. The offending
component can usually be identified with a stack trace.
Arg2: 0000000000000501, The DPC time count (in ticks).
Arg3: 0000000000000500, The DPC time allotment (in ticks).
Debugging Details:
DUMP_CLASS: 1
DUMP_QUALIFIER: 401
BUILD_VERSION_STRING: 10240.16841.amd64fre.th1_st1.160408-1853
SYSTEM_SKU: LENOVO_MT_20DK_BU_Think_FM_ThinkPad S1 Yoga 12
SYSTEM_VERSION: ThinkPad S1 Yoga 12
BIOS_VENDOR: LENOVO
BIOS_VERSION: JEET69WW (1.18 )
BIOS_DATE: 07/24/2015
BASEBOARD_MANUFACTURER: LENOVO
BASEBOARD_PRODUCT: 20DKS09J00
BASEBOARD_VERSION: SDK0E50510 WIN
DUMP_TYPE: 1
BUGCHECK_P1: 0
BUGCHECK_P2: 501
BUGCHECK_P3: 500
BUGCHECK_P4: 0
DPC_TIMEOUT_TYPE: SINGLE_DPC_TIMEOUT_EXCEEDED
CPU_COUNT: 4
CPU_MHZ: 8f7
CPU_FAMILY: 6
CPU_MODEL: 3d
CPU_STEPPING: 4
BUGCHECK_STR: 0x133
STACK_TEXT:
fffff803`4ef03c18 fffff803`4d00b44e : 00000000`00000133 00000000`00000000 00000000`00000501 00000000`00000500 : nt!KeBugCheckEx
fffff803`4ef03c20 fffff803`4ceeec06 : ffffe001`5e382000 00000000`000bddf4 00000000`00000002 fffff803`4d1ed180 : nt! ?? ::FNODOBFM::`string'+0x2334e
fffff803`4ef03cb0 fffff803`4cee996d : 00000000`00000000 00000000`0000138a 00000000`00000000 00000000`00000004 : nt!KiUpdateRunTime+0x56
fffff803`4ef03d10 fffff803`4ce1baa6 : 00002a05`3cfdd46a fffff803`4eef5400 fffff803`4eef4ef0 00000000`00000000 : nt!KeClockInterruptNotify+0x53d
fffff803`4ef03f40 fffff803`4cf5e7d7 : fffff803`4ce652e0 00000000`00000008 fffff803`4ef03f50 00000000`00000010 : hal!HalpTimerClockInterrupt+0x56
fffff803`4ef03f70 fffff803`4cfda89a : fffff803`4ce652e0 ffffe001`5e59f530 00000000`00000000 ffffe001`5a359501 : nt!KiCallInterruptServiceRoutine+0x87
fffff803`4ef03fb0 fffff803`4cfdacc7 : ffffe606`efa7fb7a 00000000`0000000a fffff800`0000400d 400d0000`e10f0c00 : nt!KiInterruptSubDispatchNoLockNoEtw+0xea
fffff803`4eef4ef0 fffff803`4cee7e78 : ffffe001`5a359501 ffffe001`62669300 ffffe001`5e437b70 fffff800`5962e090 : nt!KiInterruptDispatchNoLockNoEtw+0x37
fffff803`4eef5080 fffff803`4cf5ea32 : 00000000`00000002 fffff800`00000000 ffffe001`00000000 ffffe001`5e437b70 : nt!KxWaitForSpinLockAndAcquire+0x18
fffff803`4eef50b0 fffff800`595dd044 : ffffe001`63c6a5b0 ffffe001`5e437b70 ffffe001`5a359540 ffffe001`63c6a5b0 : nt!KeAcquireSpinLockRaiseToDpc+0x32
fffff803`4eef50e0 fffff800`5969eedd : ffffe001`00000000 fffff800`598e1880 ffffe001`629b82a0 fffff800`575cf035 : Netwtw02+0x5d044
fffff803`4eef5110 fffff800`595d32c0 : 00000000`00000000 ffffe001`62669300 00000000`00000000 fffff800`59608293 : Netwtw02+0x11eedd
fffff803`4eef5190 fffff800`59633d13 : fffff803`4eef5400 fffff803`4eef5330 ffffe001`5a359540 ffffe001`5e437b70 : Netwtw02+0x532c0
fffff803`4eef51e0 fffff800`59632ba6 : 00000000`0001aabe fffff803`4eef5330 fffff800`5985d0f8 fffff800`5985d0f8 : Netwtw02+0xb3d13
fffff803`4eef5230 fffff800`59635217 : 00000000`0000002a fffff800`5985d110 00000000`00000018 fffff803`4eef5430 : Netwtw02+0xb2ba6
fffff803`4eef53c0 fffff800`5982bc13 : fffff803`4eef55b0 ffffe001`00000000 fffff800`59844838 fffff800`5982003c : Netwtw02+0xb5217
fffff803`4eef5550 fffff800`5982dfc8 : 00000000`00000008 ffffe001`5e6bdeb0 ffffd001`03aea004 00000000`00000004 : Netwtw02+0x2abc13
fffff803`4eef55a0 fffff800`59829406 : ffffd001`03ab4084 00000000`000000ff ffffe001`5e6bdd98 fffff803`4ce1a854 : Netwtw02+0x2adfc8
fffff803`4eef55e0 fffff800`59829f4d : ffffe001`5e56c440 0000000a`a074fa37 00000000`00000001 ffffe001`5e43e2ff : Netwtw02+0x2a9406
fffff803`4eef5680 fffff800`5981f86a : ffffe001`00000001 ffffe001`5e45d3c0 ffffe001`5e515980 00000000`80000000 : Netwtw02+0x2a9f4d
fffff803`4eef5710 fffff800`575b8424 : 00000000`00000000 00000000`00000000 ffffe001`5e6f9b90 fffff800`56a636f1 : Netwtw02+0x29f86a
fffff803`4eef5780 fffff803`4cee8c65 : fffff803`4eef5b20 fffff803`4cf12437 00000100`00010100 00000002`ffffffff : ndis!ndisInterruptDpc+0x1c4
fffff803`4eef58c0 fffff803`4cee8340 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiExecuteAllDpcs+0x275
fffff803`4eef5a10 fffff803`4cfdc22a : fffff803`4d1ed180 fffff803`4d1ed180 fffff803`4d263740 ffffe001`63932800 : nt!KiRetireDpcList+0xe0
fffff803`4eef5c60 00000000`00000000 : fffff803`4eef6000 fffff803`4eef0000 00000000`00000000 00000000`00000000 : nt!KiIdleLoop+0x5a
STACK_COMMAND: kb
THREAD_SHA1_HASH_MOD_FUNC: 86c25b02910e3eb78ff372a61b597deae6054951
THREAD_SHA1_HASH_MOD_FUNC_OFFSET: 560a522e15efbd6cacb4f399ebd7b85ebd84cdb4
THREAD_SHA1_HASH_MOD: 77786a92300b36f9e6d0ec053718e14584cf4d0e
FOLLOWUP_IP:
Netwtw02+5d044
fffff800`595dd044 884308 mov byte ptr [rbx+8],al
FAULT_INSTR_CODE: f084388
SYMBOL_STACK_INDEX: a
SYMBOL_NAME: Netwtw02+5d044
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: Netwtw02
IMAGE_NAME: Netwtw02.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 5679a9da
BUCKET_ID_FUNC_OFFSET: 5d044
FAILURE_BUCKET_ID: 0x133_DPC_Netwtw02!Unknown_Function
PRIMARY_PROBLEM_CLASS: 0x133_DPC_Netwtw02!Unknown_Function
TARGET_TIME: 2016-06-15T19:01:20.000Z
OSBUILD: 10240
OSSERVICEPACK: 0
SERVICEPACK_NUMBER: 0
OS_REVISION: 0
SUITE_MASK: 272
PRODUCT_TYPE: 1
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
OSEDITION: Windows 10 WinNt TerminalServer SingleUserTS
OS_LOCALE:
USER_LCID: 0
OSBUILD_TIMESTAMP: 2016-04-09 00:48:24
BUILDDATESTAMP_STR: 160408-1853
BUILDLAB_STR: th1_st1
BUILDOSVER_STR: 10.0.10240.16841.amd64fre.th1_st1.160408-1853
ANALYSIS_SESSION_ELAPSED_TIME: 46dc
ANALYSIS_SOURCE: KM
FAILURE_ID_HASH_STRING: km:0x133_dpc_netwtw02!unknown_function
FAILURE_ID_HASH: {572b67dd-625a-961a-890f-5e687563ff62}
