Driver version:
18.33.0.2 installed via Intel driver update utility
Driver date:
28th January 2016
Problem description:
1.) Using the "Connect" feature of Windows 10 to Microsoft wireless display adapter doesn't work, tested devices with other Wi-Fi modules, no problem:
https://www.microsoft.com/surface/en-us/accessories/wireless-display-adapter-2 Microsoft Wireless Display Adapter
2.) WiDi doesn't work either, connecting to a WiDi certified receiver: the Microsoft Wirless Display Adapter, same as above.
The Wireless Display Adapter uses Wi-Fi CERTIFIED™ Miracast® technology, so you're not limited to certain apps or content streaming; you can display everything from your device on an HDTV or monitor. The Wireless Display Adapter is also an Intel® Wireless Display (WiDi) certified adapter and works with 2-in-1s and tablet devices with Intel WiDi capability.
3.) Bluetooth mouse stopped working for a while from time to time, for about 10 seconds, and then come back, which never happened before.
- « Previous
- Next »
Kenofstpehen,
With the new Windows®10 Anniversary update, Intel® WiDi is removed since it is not compatible with it anymore. Please, let us know if you have further questions or doubts. We will be more than glad to clarify any doubts and answer any other questions you may have.
Aleki
Hi Aleki,
Wireless display problem is solved, confirmed.
Problem left is the Bluetooth mouse stopped working 5-10 seconds from time to time.
This Microsoft Sculpt Comfort Mouse works fine with all my other devices.
Ken
kenofstephen,
Thanks for letting us know that all is working fine. Should have any further questions or doubts, please do not hesitate to contact us.
Aleki
- « Previous
- Next »
