Hi, I'm on Windows 11 22000.160 build, and i have an Intel® Wireless-AC 9260 160MHz card on my pc with 22.70.0.6 driver , on windows 10 i had no problem with wifi, now there is some problems, the card detect wireless access points and connects to them if i'm close to the source, but if i'm a little bit distant it disconnect and wouldn't reconnect anymore unless i go closer to the source again, seeing the log of wlan-autoconfig service, it says with id error 8002 "Preshared key probably mismatched" but the key is right in fact if i go closer to the source of the wifi, as previously said, the connection turns back. I've already tried to reinstall windows and some other fix suggested on this section but nothing works. Any suggestions?
