Wireless
8711 Discussions
Wireless AC 9462 constant disconnection problem.
Bren10
Hi Guys
I have this wireless issue that recently started after updating my computers drivers. My wifi drops connection and displays a little yellow triangle on the adapter in device manager. Then i can't reconnect.
I have attached my system info.
AndrewG_Intel
Hello Bren10
In order to check this further, could you please provide the folliwng details:
1- We understand that the problem started after updating the drivers. Do you mean updating to the Intel® generic drivers or updating to the customized drivers downloaded from your computer manufacturer's (OEM) website (Dell*)?
2- Are you having issues with Wi-Fi only or with Bluetooth too (both)?
3- Is the Intel® Wireless-AC 9462 the original wireless adapter that came pre-installed in your system or did you install it on the laptop?
4- Despide the driver updates, was there any other change? For instance, Windows® updates?
5- Are you seeing any error code (e.g. Code 10) on Device Manager? For instance, when the little yellow triangle is present in Device Manager?
6- Have you tried a different router or Access point for testing purposes? Have you rebooted your access-point, router, modem? Please provide details.
7- Have you tried a roll back to a previous driver version for testing?
8- Have you checked if this issue happens on different networks? Is this issue happening at home, office environment, or both?
Andrew G.
AndrewG_Intel
Hello Bren10
We are checking this thread and we would like to know if you need further assistance. Please do not hesitate to contact us back.
Andrew G.
AndrewG_Intel
Hello Bren10
We have not heard back from you so we will proceed to close this thread now. Generally speaking, this type of issues where there is a little yellow traingule in Device Manager may appear due to hardware issues or faulty components, so our last recommendation is to verify with your computer manufacturer (OEM) for a possible physical inspection and to see if any component (e.g. Wireless adapter) requires to be replaced.
If you need any additional information, please submit a new question as this thread will no longer being monitored.
Andrew G.
