Ich weiß nicht warum es meine neuen Zeilen entfernt hatte. Tut mir leid. Aber kann es nicht bearbeiten.
- Tags:
- Don
Hello JJBlue,
Thank you for posting on the Intel* Community.
Our support is only provided in English. We may not be able to translate the screenshots attached to the thread. To better assist you, we use a translation tool, hence; the translation may not be completely accurate.
Please provide us with the below information:
- Provide the model of the old wireless card you tested.
- Is the wireless card an integration you made to your system?
Provide us with the below report:
Intel® System Support Utility (Intel® SSU)
- Download the Intel SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
- Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
- Click on the menu where it says "Summary" to change to "Detailed View".
- To save your scan, click on "Next", then "Save".
Maria R.
Hello Maria_R_Intel,
Sry, forgot to write in English and sry for my english too.
I tested it on a other computer with wireless card (Intel(R) Wireless-AC 9462). It always connect with 802.11n, so I thought the problem is my new computer. But today the other pc has the same problems.
When I connect the computers with the Windows hotspot, it works fine with 802.11n.
The question now is whether my new router (7530AX FritzBox) is the problem? And I don't understand, why Windows with 5GHZ connects to 802.11a although it is not active in the router. I understand when it use a lower protocoll if the computer is far away, but it doesn't work when it is directly in front of the router.
Thanks for helping.
Hello JJBlue,
We are glad to know you found a solution, thank you for taking the time to share this fix, and hopefully, it may help other community members experiencing similar behavior. Since the thread is now solved, we will proceed to close it.
Maria R.
