Wireless
All support for Intel NUC 7 - 13 systems has transitioned to ASUS. Read latest update.
7309 Discussions
Wireless card for a Gateway 3522 laptop
BGrap
Hi Intel staff,
I was reading the forums for any information about the wireless card in a Gateway 3522 laptop. According to the internet, I believe the card is an Intel Wireless-N 2200 B/G card. Discontinued since 2009, I have no support for the Windows driver, right ? The reason I can still use the wireless card is that it works in Linux. The connection icon in Windows is non-existent: only the ethernet and Broadcom LAN adapter 1394 icons appear !
Please provide an archived Windows XP SP3 driver. If not, I will be using the wireless card in Linux. Thanks, and I look forward to your reply.
Brian Grapilon
AlHill
Sorry, these files have been removed for discontinued products. If gateway does not have the downloads for your laptop, you should consider two things:
a) purchase a usb dongle that provides wifi for the current world (not B and G, but N or AC).
b) purchase a new or newer laptop that supports Winfows 10, as XP was discontinued in 2014 (five years ago). Running XP is a huge risk for you.
Doc
BGrap
Thanks Al, for the response. I had an extra USB dongle wireless adapter, and am using it to download and update my old computer. I will set up this old computer for Linux. Actually, it already is a triple-boot machine, with OpenSUSE 12.3 and Puppy Linux 6.3.2 as the other OS's.
I would like to set this laptop up as a file server in Linux. Too bad I cannot use Windows XP Pro SP3 to do this ! I will consider upgrading to WIndows 7 Pro, but maybe consider the end of life cycle of Win 7 too. Thank goodness for Linux !
Brian
AlHill
yes, W7 is history in January, and W8.x is not worth considering.
Doc
n_scott_pearson
I have a backup of the necessary versions of the Wireless software (version 18.40.4) that you need for this wireless card, but only for Windows 7 and Windows 10. If you would like it, send me a private message that includes your home email address.
BTW, if you have a valid and active Windows 7 license, you can still use its license key to install Windows 10. I do not know how long this capability will continue to work, however. There are two downsides to consider:
  1. You cannot do this via upgrade; you must do a from-scratch install.
  2. This Windows 7 license will be permanently tied to this particular PC and, if it dies, the license dies with it (i.e. you cannot use it to install Windows 7 or Windows 10 on a replacement PC).
Hope this helps,
