Wireless
Issues related to Intel® Wireless Adapters and technologies
The Intel sign-in experience is changing in February to support enhanced security controls. If you sign in, click here for more information.
6422 Discussions
Wireless n1000 on windows 8.1 BSOD on PPPOE
BBoue
Hi
I have HP pavilion and it has intel centrino wireless-n 1000 with windows 8.1
I have the latest drivers installed with NETwsw00 version 15.9.0.4
After I connect to PPPOE I get BSOD Kernel_Mode_Trap
031314-23546-01.dmp13/03/14 12:24:19 PMUNEXPECTED_KERNEL_MODE_TRAP0x0000007f00000000`00000008fffff802`03935e70fffff802`0391fef0fffff800`1829f069Netwsw00.sysNetwsw00.sys+2a069Intel® Wireless WiFi Link DriverIntel® Wireless WiFi Link AdapterIntel Corporation15.9.0.4x64ntoskrnl.exe+153fa0C:\WINDOWS\Minidump\031314-23546-01.dmp4159600280 50413/03/14 12:25:21 PM
Here is the .dmp file:
https://onedrive.live.com/redir?resid=86D63638ED3FBD5%21256 https://onedrive.live.com/redir?resid=86D63638ED3FBD5%21256
Can anyone help?
Bob
Jose_H_Intel1
I do understand the inconvenience of encountering this type of issue and I have some questions about it.
I see the above driver file version; however, would you please verify the driver version shown in Device Manager?
Can you provide a description of your network environment, like a network map?
Did you test this connection using a different system?
BBoue
As for the network environment, it is a typical home set-up.
I only had the BSOD problem after the windows 8.1 update. On windows 8 it was fine.
Jose_H_Intel1
Is this wireless driver version the same you used in Windows* 8? Did you test with an older version?
BBoue
No, this is the latest driver for 8.1 I downloaded from intel website.
The problem was on going since I updated to windows 8.1 last year. I tried several drivers that came out since then.
I also tried deleting it and using the old driver that shipped with MS windows. Same problem.
Jose_H_Intel1
Let me investigate further. Please stand by.
