Wireless
7429 Discussions
Wireless n1000 on windows 8.1 BSOD on PPPOE
BBoue
Hi
I have HP pavilion and it has intel centrino wireless-n 1000 with windows 8.1
I have the latest drivers installed with NETwsw00 version 15.9.0.4
After I connect to PPPOE I get BSOD Kernel_Mode_Trap
031314-23546-01.dmp13/03/14 12:24:19 PMUNEXPECTED_KERNEL_MODE_TRAP0x0000007f00000000`00000008fffff802`03935e70fffff802`0391fef0fffff800`1829f069Netwsw00.sysNetwsw00.sys+2a069Intel® Wireless WiFi Link DriverIntel® Wireless WiFi Link AdapterIntel Corporation15.9.0.4x64ntoskrnl.exe+153fa0C:\WINDOWS\Minidump\031314-23546-01.dmp4159600280 50413/03/14 12:25:21 PM
Here is the .dmp file:
https://onedrive.live.com/redir?resid=86D63638ED3FBD5%21256 https://onedrive.live.com/redir?resid=86D63638ED3FBD5%21256
Can anyone help?
Bob
Jose_H_Intel1
I do understand the inconvenience of encountering this type of issue and I have some questions about it.
I see the above driver file version; however, would you please verify the driver version shown in Device Manager?
Can you provide a description of your network environment, like a network map?
Did you test this connection using a different system?
BBoue
As for the network environment, it is a typical home set-up.
I only had the BSOD problem after the windows 8.1 update. On windows 8 it was fine.
Jose_H_Intel1
Is this wireless driver version the same you used in Windows* 8? Did you test with an older version?
BBoue
No, this is the latest driver for 8.1 I downloaded from intel website.
The problem was on going since I updated to windows 8.1 last year. I tried several drivers that came out since then.
I also tried deleting it and using the old driver that shipped with MS windows. Same problem.
Jose_H_Intel1
Let me investigate further. Please stand by.
