Windows 10 64bits 1909
Driver AX200
Certains routeurs ainsi que des printers HP tous éloignés (CHAN=1 seulement) voient leur puissance de signal (entre -80 et -70dbm) passer à plus de -20dbm . Bug quelque part.
Merci de votre retour
Hello RDITT2
It is worth mentioning that our support is only provided in English. We may not be able to translate screenshots attached to the thread. To better assist you, we use a translation tool embedded in this Intel Community.
In order to understand better your inquiry and environment, could you please provide the following details?
1- Please elaborate more on your inquiry and the information you are looking for.
2- Are you having issues with Wireless, Bluetooth, or both? Please provide details.
3- How many systems do you have with the Intel® Wi-Fi 6 AX200?
4- We understand that the wireless adapter is connected to the M.2 slot or integrated/connected to a PCI adapter?
Does it mean that you installed it on the computer? Are you a system integrator? Or did the Intel® Wi-Fi 6 AX200 come pre-installed in the system (factory configuration)?
Please provide details including the PCI adapters you are using (brand, model, etc.).
5- How are you checking the signal power?
6- When you mentioned "CHAN1", do you mean WiFi channels?
7- Please provide PC brand and models:
Andrew G.
Hello Andrew
Thanks for your interest on my request.
previous reply sent by error, please forget it
Hello Andrew
Best regards
Ron
Please find below a screenshot of encountered issue (Livebox-F550 & orange wifi signals)
Hello RDITT2
Thank you for your response.
Please allow us to check this information further and we will be updating this thread soon.
Also, we send you a private message to gather some additional details.
Andrew G.
Hello RDITT2
Thank you for your patience in this matter.
After checking this further, we noticed that both wireless cards were added to the systems laptop and PC desktop (Wireless integration).
Installation or use of Intel® Wireless Adapters is subject to country-specific legal regulations and it is always recommended to check first with the Original Equipment Manufacturer (OEM) of the laptop, motherboard or desktop PC before installing Wireless cards. For more information please refer to the Regulatory Information Regarding Wireless Hardware Installation or Upgrade.
The Ziyituod ZYT-AX200 is actually considered a third-party wireless card (using Intel® Wi-Fi 6 AX200 chip) and we recommend checking further with the manufacturer of this PCI Wireless card since they are the ones that integrated the chip in the PCI adapter and also they are the ones that handle all the technical specifications for this device including the option of providing their customized drivers.
For the M.2 module AX200NGW added to the HP Elite Book Folio 9480m, the HP* website mentions that this laptop only comes with the following Wireless Adapters:
Having said that, we cannot guarantee that the Intel® Wi-Fi 6 AX200 added to this laptop will work fine nor we cannot confirm full compatibility. Since this is happening on Channel 1 and band 2.4GHz only, then most likely this could be due to the wireless integration.
For this reason, we kindly recommend you to check this further with HP* support to confirm compliance of Regulatory Information Regarding Wireless Hardware Installation or Upgrade and additional information and support options.
Andrew G.
*Links to third-party sites and references to third-party trademarks are provided for convenience and illustrative purposes only. Unless explicitly stated, Intel® is not responsible for the contents of such links, and no third party endorsement of Intel® or any of its products is implied.
Hi Andrew,
I understand your position as I worked for large computers companies as Customer Support Manager...
I'll not join either HP for M.2 module nor Ziyituod for the PCI card as this is not a big issue for me.
But I preferred to communicate what I discovered in case it could help somebody.
For your information, I've just tested the system having the Ziyituod PCI card with Ubuntu 20.04 LTS... I used LinSSID and I saw the same issue (on WiFi 2.4, CHAN=1 sometime some signals could have 100% quality up to -15dbm).
Best regards & Many thanks for all.
Ron
Hello RDITT2
We appreciate you took the time to join the community and share the feedback about this behavior. It has been a pleasure to assist you.
Sincerely,
Andrew G.
