Wireless
7440 Discussions
ax210偶尔开机时蓝牙出现问题
Kch-I
屏幕截图 2021-06-21 190906.png屏幕截图 2021-06-21 191637.png屏幕截图 2021-06-21 191703.png屏幕截图 2021-06-21 191735.png屏幕截图 2021-06-21 191754.png屏幕截图 2021-06-21 191817.png屏幕截图 2021-06-21 192109.png ax210,蓝牙5.2,系统为windows10 21H1,重启有时能好,重装驱动也能好。
David_G_Intel
Hello @Kch-I
Thank you for posting on the Intel️® communities.
Our support is only provided in English. We may not be able to translate screenshots attached to the thread. To better assist you, we use a translation tool, hence; the translation may not be completely accurate.
Please provide a detailed description of the problem, troubleshooting steps you tried and the Intel® System Support Utility (Intel® SSU) results
  • Download the Intel SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows
  • Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
  • Click on the menu where it says "Summary" to change to "Detailed View".
  • To save your scan, click on "Next", then "Save".
David G
Intel Customer Support Technician
David_G_Intel
David G.
David_G_Intel
David G.
