Wireless
8409 Discussions
ax210 bluetooth audio
evage6520
My bluetooth headphones are pairing via the ax210, but can't play bluetooth audio, nor appear as sound device in windows 11. Any ideas please?
Jean_Intel
Hello evage6520,
  • Is this a laptop or desktop system? Provide me with the model of the system
  • Is the Bluetooth working as expected on other devices?
  • Do you experience any issues with WiFi?
  • Do you remember if this issue happened after a new OS update or Wireless driver update?
  • Is this the original adapter that came pre-installed in your system or have you changed/installed a new adapter recently?
Jean O.
evage6520
Thank you for your reply. It is a mini pc as follows
AZW Green G2
BIOS
Version
JTKT001
Date
3/11/2022
MOTHERBOARD
Manufacturer
AZW
Model
Green G2
Version
Default string
OPERATING SYSTEM
Edition
Microsoft Windows 11 Pro (64-bit)
Version (Build)
21H2 (10.0.22000)
Devices and Drivers
PROCESSOR
Intel® Celeron® N5095 @ 2.00GHz
GRAPHICS
Intel® UHD Graphics
AUDIO
USB Audio Device
USB Audio Device
USB Audio 2.0
NETWORKING AND I/O
Realtek PCIe GbE Family Controller
Intel® Wi-Fi 6E AX210 160MHz
ASIX AX88179A USB 3.2 Gen1 to Gigabit Ethernet Adapter
Intel® Wireless Bluetooth®
MEMORY
8 GB
STORAGE
NORELSYS 1081CS0 USB Device
SCY SSD 64GB N10C
NORELSYS 1081CS1 USB Device
Problem appeared after installing the ax 210 wireless card. Bluetooth on other devices works fine.
Wireless fine.
evage6520
Hi Jean, any advise for me?
Jean_Intel
Hello evage6520,
I appreciate your response.
You mentioned that the issue started after installing the ax210 wireless card. Does it mean that you add/integrate the wireless card to your system?
Jean O.
evage6520
Hey Jean, the problem was solved by reinstalling Windows! I have one more question for you. How can I install aptx codec support for the ax 210?
Jean_Intel
Hello evage6520,
I am glad to hear that the issue is now solved.
Regarding your question, according to the Bluetooth features list by edition on the Microsoft support page, the Apt-X codec is supported in Windows 10. However, if you want more information as to how to enable it, I would recommend contacting Microsoft support for more information about how to enable it, keep in mind that it's a feature of the Operating System.
https://docs.microsoft.com/en-us/windows-hardware/design/component-guidelines/bluetooth
Jean O.
Jean_Intel
Hello evage6520,
I hope you are doing fine.
I have not heard back from you. So we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
XB56
I have this same problem after just installing AX210 in a Lenovo T14 laptop with Ryzen 5 Pro 4650U. Devices paired and showing as connected to Bluetooth in Windows 11 don't appear as connected with audio but as soon as I play music, they disconnect and sound goes to the internal sound card. I've uninstalled the Bluetooth adapter, updated to the latest Intel Bluetooth and wifi drivers. run the Bluetooth troubleshooter, paired, deleted, and re-paired multiple devices, and reinstalled Windows. Three different Bluetooth audio devices do the exact same thing. Suggestions are welcome.
